belts loose
belts loose
Postby bluemaumau » Fri May 05, 2006 4:56 pm
just put the 4agze back together.
however the belt on that runs the s/c>tensioner>crank>water pump>s/c
is really really loose. like its hanging from all the pulleys.
strange thing is i havnt adjusted anything.
im using the same belt that was already on the engine
(as mine is 3 weeks ex jappaland)
so wtf!
why is this and how do i fix
will
Postby Grrrrrrr! » Fri May 05, 2006 5:52 pm
You haven't somehow put the wrong idler pulley on have you? like maybe the swapped the idler pulley from the P/S and Alt belt onto that side of the engine have you?
What parts have been changed?
Grrrrrrr!
Postby bluemaumau » Fri May 05, 2006 7:16 pm
no they are the same size anyway, i checked. but i have got the right one on.
replaced:
w pump
cambelt
c belt tensioner
p/s a/c belt
alt a/c belt. basically all belts but s/c belt
omg so $&#$% stupid :oops:
i put the belt on the underside of the idler.
its supposed to be on top right???
omfg :oops: :oops: :oops:
Postby bluemaumau » Fri May 05, 2006 7:27 pm
alright so im gonna go fix it soon.
whats a good way to know if the belts to tight?
as ill need to readjust the idlers.
so yea how do you know how tight to go???
Postby flat_0ut » Fri May 05, 2006 7:30 pm
bluemaumau wrote:so yea how do you know how tight to go???
would need the car service manual wouldnt you?
flat_0ut
Postby bluemaumau » Fri May 05, 2006 7:31 pm
they dont do em for gzes
Postby bluemaumau » Fri May 05, 2006 7:32 pm
plus im not taking about how tight the nuts on them need to be. im talking about the belts ie how tight should they be? (idler position)
Postby 2LTR Rona » Fri May 05, 2006 7:42 pm
does this pic help with belt layout ? (wont post pic as its rather large)
http://www.billzilla.org/4agonground.jpg
the CAM belt tensioner will take the slack up for you as its controled by the sping attached to it
as for the other belt you can adjust the tightness by swinging off a long bar acting as a leaver off the alternator, sure you want it tight but not to the point where you are almost snapping the belt.
2002 Altezza, 1974 KE25
2LTR Rona
Postby bluemaumau » Fri May 05, 2006 7:44 pm
2LTR Rona wrote:does this pic help with belt layout ?
not at all.
i saw it on google to.
but i found out the prob. belts were on wrong sides of idlers. :oops:
done now 8)
Postby 2LTR Rona » Fri May 05, 2006 8:04 pm
bluemaumau wrote:but i found out the prob. belts were on wrong sides of idlers. :oops:
done now 8)
dont worry man, been there done that :oops: :lol:
All good now its done though 8)
2LTR Rona
Users browsing this forum: No registered users and 38 guests
