4AGE 16v into 90' Corolla liftback AE92
Postby 1JZ » Wed Jun 14, 2006 11:27 pm
Hey all,
I have a 90' Corolla 5 door liftback, which i believe is a AE92 model. It currently has the 4A-FE carb engine. I am wanting to convert it to a 16valve 4AGE. I have the option to buy a 85' Corolla FX-GT, which has the 4AGE and manual in it. My questions are; Will the 4A-GE bolt straight into my AE92 with the factory 4A-FE engine mounts, or will the FX-GT engine mounts bolt into the AE92? How hard is the wiring to do?, i have heard the wiring loom will not connect straight up to the dash in my AE92, can anyone confirm this, or has anyone done this conversion and can let me know any tips when it comes to the wiring? As the AE-92 came with a carburated engine, and the 4A-GE is fuel injected, do i need to change the fuel pump/lines etc?
Any help would be greatly appreciated,
Thanks
1JZ
Postby KinLoud » Wed Jun 14, 2006 11:48 pm
I'm parting out my FXGT AE92 - I can sell you the fuel tank and fuel lines - they should bolt straight into your car.
Wiring - shouldn't be too hard - the 4age looms can be sorted out with 3 or 4 wires that need to connect to your body loom.
Ken
Ham
021 408 863
Postby peas » Wed Jun 14, 2006 11:51 pm
A series engine will bolt in and as a side note 4A-FE is injected.
'97 Caldina GT (ST215G)
peas
Postby bluemaumau » Thu Jun 15, 2006 1:02 am
peas wrote:A series engine will bolt in and as a side note 4A-FE is injected.
some 4afe were carbeb, mostly ae92.
Postby fuel » Thu Jun 15, 2006 11:45 am
If it were carbed then it would just be a 4A-F. The E means 'multi port fuel injection'.
LOUD NOISES!!!
fuel
Postby bluemaumau » Thu Jun 15, 2006 11:47 am
true. didnt read lol.
Postby bluemaumau » Thu Jun 15, 2006 11:49 am
is your liftback auto or manual?
Postby 1JZ » Thu Jun 15, 2006 3:47 pm
hey, my liftback is a manual :D
1JZ
Postby bluemaumau » Thu Jun 15, 2006 3:53 pm
well that makes it abit easier then. so is your car carbed or efi?
Postby fuel » Thu Jun 15, 2006 4:49 pm
He said in his first post its carb'd. It's a NZ-new liftback, probably an XL or GL model.
LOUD NOISES!!!
fuel
Re: 4AGE 16v into 90' Corolla liftback AE92
Postby bluemaumau » Thu Jun 15, 2006 6:35 pm
1JZ wrote:4A-FE carb engine.
Postby fuel » Thu Jun 15, 2006 10:46 pm
Yes but we already established that a 4A-FE can't be a carb'd engine. Either it'a a 4A-F carb, or a 4A-FE injected. Considering he asked if he needed to replace the fuel lines and tank going from carb to injected, I would safely bet that he has a 4A-F carbd engine, and that the 4A-FE was a typo or a mistake.
LOUD NOISES!!!
fuel
