lorolla24 wrote:Nah, ive got a good steady rpm.
Ive just taken the timing cover off and i can see 2 dots on the intake cam pulley, a big and small one. the exhuast has a 1 small dot.
with it at the moment the small dots are lined up sweet but with the tappet cover off you can see the inlet valves are pused in on the compression stroke...ohoh.
What is the big dot on intake pully
lorolla24 wrote:There was ALOT of smoke,
But its the only thing that can explain why it looks like OIL on the outside of the wrap.
Still think i need a restrictor for the turbo oil feed though,it's runnig about 42PSI oil pressure.
Turbo is a (GT28)"ball bearing"
