Gearbox problems
Gearbox problems
Postby ollieboy » Mon Aug 07, 2006 12:56 am
I have a car that only just started doing this this morning. It was driving along fine but then started acting funny, when I put the clutch in and took out of gear I would need to double clutch to get back into a gear. It did this on all gears. Then it got worse and with the clutch in the car still moved in gear. Now I can't get into gear with the engine going at all and I need to start in gear. What could this be?
I hope you can understand the problem, you might need more info to answer it though, just let me know.
Ollie
ollieboy
Postby fivebob » Mon Aug 07, 2006 1:05 am
Sounds like a problem with the clutch.
Postby ollieboy » Mon Aug 07, 2006 1:07 am
I thought as much, would it be more likely a matter of adjustment or a new clutch?
ollieboy
Postby sergei » Mon Aug 07, 2006 1:20 am
most likely that seals in the clutch slave cylinder gave up...
Postby flat_0ut » Mon Aug 07, 2006 12:55 pm
bleed the clutch?
flat_0ut
Postby bluemaumau » Mon Aug 07, 2006 5:12 pm
make sure your gearbox is full of oil
Postby Punter » Mon Aug 07, 2006 5:50 pm
sergei wrote:most likely that seals in the clutch slave cylinder gave up...
x2 Thats happened to me before, just like you described.
Punter
Postby matt dunn » Mon Aug 07, 2006 7:31 pm
Sounds exactly like the problem i struck in my race car yesterday,
leaking slave cylinder and running out of clutch fluid..
Just check the clutch fluid level and see where it is.
If it's low you need to top it up and bleed it and check for leaks.
Matt
Postby ollieboy » Mon Aug 07, 2006 8:45 pm
Cool, thanks for your help, will have a look when I can.
Ollie
ollieboy
Postby KwS » Mon Aug 07, 2006 9:04 pm
x3. happened to me too. had to rebuild the slave, and then its all good.
KwS
Postby Black » Tue Aug 08, 2006 1:15 pm
funny, same thing happened to my trueno on friday. and when i got in it on saturday it was fine again. was just like you said. i couldn't get it out of gear and when tryed to put it in gear was like the clutch wasn't working at all.
Black
Postby ollieboy » Fri Aug 11, 2006 8:11 pm
I've found that the Master Cylinder is leaking into the car through where the pushrod goes. What should I do about this? Is the best thing to do get a new Master Cylinder or second hand? Where can I source this part? Revhead maybe?
Cheers guys, youve helped heaps
Ollie
ollieboy
Postby RS13 » Fri Aug 11, 2006 8:33 pm
Master cylinders are reasonably cheap, depend on where you go, and the car, they go for $30 to a couple of hundred.
RS13
Postby postfach » Fri Aug 11, 2006 10:14 pm
ollieboy wrote:I've found that the Master Cylinder is leaking into the car through where the pushrod goes. What should I do about this? Is the best thing to do get a new Master Cylinder or second hand? Where can I source this part? Revhead maybe?
Ollie
Replace it, i had the same problem, get a new one, that way you dont have to worry about it happening again. There's a place called ABC on Barrys Point Road in Takapuna that should have something for you, nice and cheap too
postfach
Postby Ae92typeX » Sat Aug 12, 2006 9:30 am
tradeparts was cheap as chips too. beter than getting yours reco'd or just putting new seals in.
Ae92typeX
