Fitting rear hatch window AE86
Postby beeker » Sat Sep 16, 2006 11:40 am
Do these require window adhesive(silicon) or just clip in (with the grooves in the rubber). Any installation tips or instructions ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Rick » Sat Sep 16, 2006 12:33 pm
Are you fitting the window to a fibre glass hatch?
Postby Meadzy » Sat Sep 16, 2006 3:43 pm
hatch window i just clipped in using the string technique, no silicone, thats on a metal hatch
"Keeping it true to the JDM"
J-Spec Group
http://jspecgroup.com/forums/index.php
AE86,200sx,EG6
Meadzy
Postby beeker » Sat Sep 16, 2006 7:30 pm
Rick wrote:Are you fitting the window to a fibre glass hatch?
yes, f/glass hatch.
06 RS4 Avant
beeker
Postby Rick » Sat Sep 16, 2006 7:38 pm
You can fit the glass with the factory seal but I have seen them leak like that, might pay to put some sealant around the edges to stop that from happening. I thought you would be fitting lexan? It just so happens I got myself a fibre glass hatch also, have you looked into the prices of lexan? it seems a shame to have a light weight hatch fitted with heavy glass.
Postby Stealer Of Souls » Mon Sep 18, 2006 9:59 am
I was thinking that with the fibreglass hatch you'd actually be best off trying to silicone the glass in place and then just silicone "glueing" a strip of rubber around the edges...
That way the glass/lexan will add to the ridigity of the hatch.
'86 AE85.5 Levin
Stealer Of Souls
Postby beeker » Mon Sep 18, 2006 7:22 pm
Rick wrote:You can fit the glass with the factory seal but I have seen them leak like that, might pay to put some sealant around the edges to stop that from happening. I thought you would be fitting lexan? It just so happens I got myself a fibre glass hatch also, have you looked into the prices of lexan? it seems a shame to have a light weight hatch fitted with heavy glass.
I was tempted to use Lexan, but the cost and hassle just didnt seem worth it. I've taken ~10kg already out by the time you add up the wiper motor and steel>f/glass. I like the durability of glass, plus the idea of keeping the demister is a nice one, or just call me lazy.
06 RS4 Avant
beeker
So whats this string technique people talk about ? Got a link ?
06 RS4 Avant
beeker
Postby Meadzy » Mon Sep 18, 2006 8:39 pm
trick i got from my old man, its hard to explain, you use it to get the rubber around the glass easily
J-Spec Group
AE86,200sx,EG6
Meadzy
Postby 85AW20v » Mon Sep 18, 2006 11:00 pm
Its a length of cord - about 4mm thick - that you put into the outside seal groove all the way round after fitting the seal to the glass, overlapping it at the ends . Fit the seal to the glass and sit it in place on the hatch with the ends of the string hanging into the inside of the hatch. Pull one end of the cord downwards and it should pull the inside lip of the seal through to the inside of the hatch. Work your way round - pulling the cord down. Couple of minutes and you're done.
See ya
Simon
85 MR2 20v
85AW20v
Postby Stealer Of Souls » Mon Sep 18, 2006 11:03 pm
Mini hijack...
Are there similar tricks to getting the glass out?
'86 AE85.5 Levin
Stealer Of Souls
Postby 85AW20v » Mon Sep 18, 2006 11:07 pm
Nice even pressure - feet work well!! Someone pulling up from the outside also helps. Once you get it started, it comes out easy.
See ya
Simon
85 MR2 20v
85AW20v
Postby beeker » Tue Sep 19, 2006 3:08 am
Simon85MR220v wrote:Its a length of cord - about 4mm thick - that you put into the outside seal groove all the way round after fitting the seal to the glass, overlapping it at the ends . Fit the seal to the glass and sit it in place on the hatch with the ends of the string hanging into the inside of the hatch. Pull one end of the cord downwards and it should pull the inside lip of the seal through to the inside of the hatch. Work your way round - pulling the cord down. Couple of minutes and you're done.
perfect, thx
06 RS4 Avant
beeker
Postby Bling » Tue Sep 19, 2006 8:38 am
Stealer Of Souls wrote:Mini hijack...
viewtopic.php?t=49703&highlight=removing+windscreen
RS13 is onto it in that thread
Postby Stealer Of Souls » Tue Sep 19, 2006 9:27 am
In. Out. Front. Rear. Glued. Rubber seal.
This post now has it all...
'86 AE85.5 Levin
Stealer Of Souls
