Rick wrote:You can fit the glass with the factory seal but I have seen them leak like that, might pay to put some sealant around the edges to stop that from happening. I thought you would be fitting lexan? It just so happens I got myself a fibre glass hatch also, have you looked into the prices of lexan? it seems a shame to have a light weight hatch fitted with heavy glass.
Simon85MR220v wrote:Its a length of cord - about 4mm thick - that you put into the outside seal groove all the way round after fitting the seal to the glass, overlapping it at the ends . Fit the seal to the glass and sit it in place on the hatch with the ends of the string hanging into the inside of the hatch. Pull one end of the cord downwards and it should pull the inside lip of the seal through to the inside of the hatch. Work your way round - pulling the cord down. Couple of minutes and you're done.
Stealer Of Souls wrote:Mini hijack...
Are there similar tricks to getting the glass out?
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
