How do i set up 7mge timing?
Postby UTERUS » Sun Sep 24, 2006 12:42 pm
The 7mge in my mark2 had a blown headgasket so i have replaced it and torqued it down.
The problem i have now is aligning the cambelt and distributor up.
The crank pulley has a mark on it and the mark is pointing at 10 (degrees before/after tdc?)
The marks on the cams are pointing straight up to their (tdc?) marks aswell.
I can't verify that the distributor hasn't been played with while it was out.
The cambelt has lined up in exactly the same place on the cams, i know this because i drew a line on it that lines up with the timing mark on the cams.
What should i do next?
Cheers,
Simon
UTERUS
Postby Jason T » Sun Sep 24, 2006 6:51 pm
Fixing Toyota's since '87
Jason T
Postby Toymad » Sun Sep 24, 2006 7:00 pm
Try this page for the mechanical timing (as well as a few past it):
http://www.cygnusx1.net/Supra/Library/T ... EM&Page=22
Then for the distributor timing, go here:
http://www.cygnusx1.net/Supra/Library/T ... IG&Page=19
You may want to bookmark the site for future reference.
Toymad
Postby UTERUS » Sun Sep 24, 2006 9:43 pm
You guys are legends
UTERUS
