Akane wrote:$2G won't get you a decent turbo for 500hp.
Maybe you can get one of those whacked out T3/T4 jobbies.
dougsop wrote:hks adj cam gear
dougsop wrote:jun intake and ex sprocket slide cam
dougsop wrote:new belt
RunningRich wrote:Well frankly your list looks like a name brand wannabe wish list. HKS cams are good, there are cheaper and better options for gears. Why an HKS gasket, the stock one is great. Why do you want to replace the factory rods? Unnecessary money.
How much have you planned for block work? How much for head work? Clutch? Flywheel? Who are you taking the engine to for machine work? What bearing clearance will you run and what bearings to you plan to use to get those clearances?
500bhp is not a small ask.
