rear windscreen wiper removal
Postby mat » Sun Oct 08, 2006 5:32 pm
Hi,
My car is an 82 mz11 soarer and im trying to get the rear windscreen out to fix a bit of rust. I'm having some trouble with the wiper where it comes up through the screen, i dont know how to get the rubber seal out. It's got a metal bit over the top of it with four notches out of it but im not having much luck turning it with some long nosed pliers. is there a special tool i need or is there some other way it comes out.
Cheers for any help.
ps. If your car comes with a rear windscreen wiper do you need it working at warrent time or are you allowed to take it off at all?
Thanks.
mat
Postby Santa'sBoostinSleigh » Mon Oct 09, 2006 8:22 am
from memory when i dismantled the AE111, unbolt wiper from the outside, then pull the unit from the inside
the rubber/metal bit is attached to the window.
if you remove it, remember theres a hole in the window and it will leak
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby sergei » Mon Oct 09, 2006 9:55 am
You don't need rear wiper working for WOF.
Postby $CENSLS1$ » Mon Oct 09, 2006 10:33 am
Santa'sBoostinSleigh wrote:from memory when i dismantled the AE111, unbolt wiper from the outside, then pull the unit from the inside
Just put a bung in the hole... :roll:
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
Postby mat » Tue Oct 10, 2006 8:04 pm
thanks for the replies guys, after a bit of stuffing around i managed to get it off, it screwed off and it was super tight but a good drenching in crc i eventually got there.
Cheers.
mat
