Bolt snapped off in block...How to remove?
Postby no_8wire » Wed Oct 18, 2006 8:51 pm
As per title..As I was torquing a bolt up it snapped! :evil:
now how do I go about removing this sucker so I can get on with the re assembly of the block?
Its snapped off with a few mm protruding how ever not enough to get a decent grip on...So what do I need to do now?
no_8wire
Postby deaf_rattle » Wed Oct 18, 2006 8:53 pm
got a welder?
weld something to it and use that to get it off.
otherwise drill into it and get some "easy outs". mitre 10 sell them
Postby no_8wire » Wed Oct 18, 2006 8:55 pm
Too scared I will weld the bolt into the bolt for that! :lol:
So Easy-outs...ok will get some tomorrow.
no_8wire
Postby sergei » Wed Oct 18, 2006 8:59 pm
be very carefull with easy outs, they snap too easily...
Postby no_8wire » Wed Oct 18, 2006 9:01 pm
well the bolt snapped before 7 ft pounds...so hopefully should be easy enough to get out.. :?
no_8wire
Postby Lloyd » Wed Oct 18, 2006 9:02 pm
Get a nut just large enough to sit over it and weld around on the inside, wont end up welding to the block that way.
Oh, and if you drill it then made sure you punch it and get the drill dead centre otherwise it'll end up being a horrible job. Or just end up drilling it out lots, retapping the thread and helicoiling it (depending on what bolt you broke off)
Postby no_8wire » Wed Oct 18, 2006 9:05 pm
Front crank oil seal bolt...one of the ones that take the 10mm socket
no_8wire
Postby 85AW20v » Wed Oct 18, 2006 9:09 pm
Or put a hacksaw cut across it and unscrew it with a screwdriver.
See ya
Simon
85 MR2 20v
85AW20v
Postby no_8wire » Wed Oct 18, 2006 9:09 pm
will try that, and then welding the nut to it.
no_8wire
Postby no_8wire » Wed Oct 18, 2006 9:14 pm
:oops:
I went to cut a slot in it...and it turned!
I just took it out with my fingers...
What on earth could have caused it to snap then?
So I think I will be going and getting some 8.8 grade bolts! 8O
no_8wire
Postby Lloyd » Wed Oct 18, 2006 9:36 pm
Maybe it was actually damaged when you were undoing it. Had that happen before. Bolt broke off doing it up and when i looked where it broke it sheared off in the wrong direction but not enough to break completely
Postby Adoom » Wed Oct 18, 2006 10:11 pm
I know he has got it out. But another way to get snapped off bolts out I have used to remove a head bolt snapped off about 1mm BELOW the surface of the block. Get a piece of flat steel strap at least 2mm thick(or you might just melt the steel to the block). Drill a hole in it near an end the same size as the bolt. Stick the hole right over the top of the broken bolt and point the MIG welder down there on almost max power. Keep it going until there is no hole left in the metal strap(its full of weld). Then just turn the strap and the bolt comes undone. I wasted hours and $$ buying EZouts and getting nowhere. It took 5minutes to get it out the steel strap way!! There is also little chance of damaging the block this way cause the steal strap covers up all but the end of the bolt. Even if you get some weld 'splatter' on the block it 'wont' stick cause its cast iron.
Adoom
Postby Lloyd » Wed Oct 18, 2006 10:18 pm
Adoom wrote:Even if you get some weld 'splatter' on the block it 'wont' stick cause its cast iron.
Depending on what he is working on ;)
Postby bluemaumau » Wed Oct 18, 2006 10:36 pm
no_8wire wrote::oops:
haha that sort of stuff is so funny, good result tho! :)
Postby z0ton » Thu Oct 19, 2006 7:29 am
Has anyone tried Koken bolt twisters? Their quite good.
Go here : http://www.koken-tool.co.jp/en/ and click products and then near the bottom of the black bit its got Bolt Twisters.
z0ton
Postby RickGT » Thu Oct 19, 2006 6:23 pm
pretty much just an ez out with a socket connection on the end
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby ants_ae92 » Sat Nov 04, 2006 8:33 am
Maybe the bolt has been torqued up before, and possibly stretched? then it could have bottomed out had no where to go butsnap. Just happened to be doing up the cam journals on my 4age. Only 8-9ftlbs. Measured the bolts and they were like 1.5-2mml onger than any other cam journal bolt. Also the threads just didnt line up, the bottom half of the bolt had stretched thread, so they didnt match up to an unstretched bolt.
We used a dremel to cut a slot in the top of it so that we could unscrew it.
I guess the lesson is, always clean and inspect all bolts.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
