A/T ECU in M/T car
A/T ECU in M/T car
Postby johntramp » Fri Feb 17, 2006 12:04 am
Hey I am using an ecu from an automatic car in my manual car. I believe there is a wire I have to jump so that the ecu thinks that it is in park so that the car will start up. Does anyone know anything about this?
The ECU I am using is from an AE111 Levin.
johntramp
Postby 20v_rollaboy » Fri Feb 17, 2006 12:11 am
Yep thats right.
Im running an auto ecu on my manual 20v (ae101).
Just find the selector plug on the loom that went to the gearbox and jump two wires, or just cut the plug off and join the two wires. Sorry but I cant remember which wires were the right ones :(
20v_rollaboy
Postby johntramp » Fri Feb 17, 2006 12:43 am
Hey would it be one of these plugs by any chance?
johntramp
Postby Caveman » Fri Feb 17, 2006 12:50 am
The one in the bottom picture looks like the ignitor plug.
The black one in the top picture appears to be the tps plug, hard to tell on that angle.
Its easier to look at a wiring diagram and it'll only be one wire.
Caveman
Postby johntramp » Fri Feb 17, 2006 12:58 am
that is definately not the ignitor as it is already connected and the TPS would be at the other end of the loom.
johntramp
Postby barryogen » Fri Feb 17, 2006 7:55 am
johntramp wrote:Hey I am using an ecu from an automatic car in my manual car.
20v_rollaboy wrote:Yep thats right.
yoink, thanks guys, you just saved me ~$1200
Hopefully I'll pay you back later.
barryogen
2ZZ Guru in training
Postby johntramp » Fri Feb 17, 2006 2:00 pm
I put a 5A fuse between the two black wires on that plug to short out the connection and then started the car but got no spark. Any ideas where to start looking? Cheers
johntramp
Postby 20v_rollaboy » Fri Feb 17, 2006 9:22 pm
Where bouts are you??
20v_rollaboy
Postby KinLoud » Fri Feb 17, 2006 10:08 pm
I presume you are saying that the engine turned over which means that you must have shorted out the right connection.
No spark....
Make sure your ignitor or coil is bolted to a good earth as this can be a classic problem.
Ken
Ham
021 408 863
Postby johntramp » Sat Feb 18, 2006 10:43 am
I am from Chch.
I will try giving the ignitor a better earth.
johntramp
Postby johntramp » Sat Feb 18, 2006 2:02 pm
no :( giving the ignitor another earth didn't make any difference.
At the moment I have the starter motor wired directly off the ignition so I don't know if the computer is even turning on.
johntramp
Postby johntramp » Sun Feb 19, 2006 3:04 pm
can anyone give me any tips on tracing electrical faults? cheers
johntramp
Postby maxium » Thu Nov 09, 2006 8:23 pm
hey there did you eva get ur motor sorted?
maxium
Postby Alex B » Thu Nov 09, 2006 11:40 pm
Does not work for all cars you know.
Postby bluemaumau » Fri Nov 10, 2006 11:26 am
the black plug looks like the speedo sensor plug?
Postby crispy'86 » Fri Nov 10, 2006 2:49 pm
If you can get hold of a multimeter, turn it to ohms to check resistance. (may need a long bit of wire to clip to one probe of the multimeter) and put one end onto the plug in the engine bay and another at the ecu plug . Make sure battery is disconnected and plugs are out of the ecu before attempting to unplug the ecu plugs and caryying out this test. When you have go tthe same wire the multimeter screen should go from infinity (.1 screen display) to circuit (000 on screen display) that way you can tell if it's the right plug/ wire. mark down what wire colours are, then plug ecu plugs back in and turn key on, check there's power at the igniter, also check your fuses too
crispy'86
Postby *84vvt* » Sat Nov 11, 2006 10:05 am
*84vvt*
