by strx7 » Thu Nov 23, 2006 10:45 pm
I'd honestly like to see 1 guy do a Caldina/GT4/4wd corolla clutch with only 8 hours of labour. If the guys knows them inside out then it'd POSSIBLY be do-able, otherwise dreaming.
You do realise you have to drop the entire engine and gearbox out the bottom, which means removing both engine mounting beams, splitting them apart then putting it all back together? If your car hasn't had a cambelt & water pump done, i'd reccomend doing them while the engine is out.
Motorsport Bay of Plenty -
http://www.mbop.org.nz
