think evo 3 or evo4 injectors are 440cc...bit bigger than the ze injectors, not sure how easily they fit in though. someone on here will be able to give you more info...
IH8TEC wrote:std 365's with the extra 750cc injector, they've been cleaned and flow tested and they flow a little more than std though. i'll be going to 550's and running about 25psi when i get the new computer though.
strx7 wrote:either he's running insane fuel pressure, is at 100% duty Cycle, or he's VERY lucky, or a combo of all three.
strx7 wrote:IH8TEC wrote:std 365's with the extra 750cc injector, they've been cleaned and flow tested and they flow a little more than std though. i'll be going to 550's and running about 25psi when i get the new computer though.
4 x 550 is only 400HP worth of fuel MAXED out, 320hp at 80%. 25psi would be over that????? you need either bigger injectors or more injectors
