Can someone identify this turbo? Supra?
Postby VRFOE » Thu Nov 30, 2006 2:55 am
Hi there,
I have recently aquired a "hybrid" engine. It is a 4G93 (1.8L Mitsubishi Lancer GSR) with a custom manifold and turbo on it. I am trying to figure out exactly what turbo it is as I think it will need a rebuild or replacement as it is blowing smoke.
Person who built the engine reckons the turbo is off a Supra but can't remember which model. And someone has stated perhaps it is a CT-26 turbo?
Inlet gasket which is the SAME as a T3 :?
If anyone has any information or suggestions please let me know!
VRFOE
Postby vvega » Thu Nov 30, 2006 7:20 am
not a ct2# turbo
oil fedd and return are on the same flange
and your oil feed looks like its on the top
could be a ht18 with a skyline ex housing and a to4e front cover
but then the wastegate is wrong cause there integal with the downpipe
id go for a td05/6 with a 20g compressor for my guess
whats it go like ?
vvega
Postby VRFOE » Thu Nov 30, 2006 8:56 am
Is this correct?
bgrieger wrote:Doesnt' look like a CT to me, but it's tough to see while it's on the car. It looks more like a generic T3 housing than a CT...again, hard to tell. I was looking for the "V" band clamps that hold the housings on a CT and can't seem to see them.
All turbos can be clocked to face the outlets as needed. To look at the pics again, even the wastegate valve is on the wrong side for a CT, and is connected differently. I would again lean to the t3, or a t3/t4 hybrid turbo.
VRFOE
Postby vvega » Thu Nov 30, 2006 5:42 pm
well he raises a good point it is facing teh wrong way
and as fair as i know all garrets face teh same way too
so were back to ...soem sort of td## series turbo
i.e vr4 evo etc
vvega
Postby VRFOE » Fri Dec 01, 2006 2:09 am
vvega wrote:well he raises a good point it is facing teh wrong way
i.e vr4 evo etc
Definately not standard Mitsubishi.
Someone suggested a Skyline turbo of some sort? As they are factory T3 flanged...
VRFOE
Postby vvega » Fri Dec 01, 2006 11:31 pm
how do you know its a t3 flange
vvega
Postby VRFOE » Mon Dec 04, 2006 10:54 am
vvega wrote:how do you know its a t3 flange
Because I put a T3 gasket on it and it fit perfectly...
VRFOE
Postby vvega » Mon Dec 04, 2006 6:28 pm
did you tri a t25 :D
vvega
