right rear drum brake binding - easy q
Postby scope » Tue Jan 09, 2007 1:56 pm
this i'm thinking will be a simple question to almost every one but i don't know the answer
failed a wof on rear right drum brake binding, how to i fix it? change shoes? someone said there's a cog in the back of the drum which you can change with a screw driver, will that fix it?
thanks
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby Punter » Tue Jan 09, 2007 2:16 pm
Yeah there is a cog like thing in there, it's meant to automatically adjust the resting point of the brake shoes. They never work properly on old cars.
But even if that isn't working it shouldn't cause binding.
I'd say just pull it all apart, clean it, then re-assemble it.
Punter
Postby Dell'Orto » Tue Jan 09, 2007 4:19 pm
Could also be the wheel cylinder has gotten a bit rusted up with age and jammed partially open. Make sure its able to be pushed back in easily.
