Under shim buckets in a 4age
Postby 4agtepwr » Wed Jan 10, 2007 5:45 pm
Anyone run undershim buckets in there 4ages and wat parts are they using because short of forking out for 1s? buckets im a little stuck.
Can 3sge ones be made to fit if i machine the head to suit? Has anyone done that before?
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby matt dunn » Wed Jan 10, 2007 6:26 pm
Why run under buckets?
Years ago we used to just weld a couple of small parts around the shim to the bucket once you get the tappets set right.
Only did that because of the large cams the celica had.
Was 1GGTE not a 4AGE, but same principal applies.
Once the valve clearance is set, you should not need to set them again.
Postby 4agtepwr » Wed Jan 10, 2007 6:43 pm
Yeah another engine builder i know had done that on a couple of engines he had built so that mite be the way i go yet, just exploring options but thats defenently one of them. Oh and my reason was because the cams duration is a fair bit more than standerd.
4agtepwr
Postby 85AW20v » Wed Jan 10, 2007 8:16 pm
Echo bucket and "under bucket shims" will drop in. Email Revhead for prices.
See ya
Simon
85 MR2 20v
85AW20v
Postby Mr Revhead » Wed Jan 10, 2007 9:07 pm
thats the 1S ones he mentioned :wink:
and techniquly they are vitz as the echo never had the 1S.
yesh i can do good deals on them, but its still not a $100 option
