Seats too high - Help with brackets
Postby xRyanx » Wed Jan 10, 2007 8:31 am
So to begin with im 6'3. My seats in my bzg, while low enough, are still quite high for me. Im not hitting my head on the roof, but its close.
Also, the fact that with my smaller after market steering wheel, i can no longer see my speedo needle from 40-140kmph, is making me think of ;
A)getting some new seats
B)Possibly modifying my rail so I and the seat sit lower?
Im not after a gangsta lean. I like my seat as upright as possible. If i went aftermarket seats, are these usually lower when on their rails?
Has anyone moddified their BZ rails to have the seat sit lower?
ADMIN EDIT: oversized sig image removed - way too large
Adamal wrote:This is XRyanX. His car is so low that he has to drive over speed bumps diagonally. HARDEN THE $&#$% UP XRYANX!!
xRyanx
Postby Ae92typeX » Wed Jan 10, 2007 9:26 am
Not much of an answer, but,
going aftermarket, depending on brand etc, some (seen both some that do, and others that dont) supplied brackets can even sit you a little higher than standard.
Not a huge amount of room to mod the existing rails. imo, you still want to be able to get your hands under incase you drop your wallet etc. nothing imposible though.
Ae92typeX
Postby gurutasker » Wed Jan 10, 2007 9:42 am
Also watch that if you're seat belts are mounted to the seat (which I think they are on the AE111's) and not the chassis. If you try and go after-market with your seats you will have to re-mount the seat belt stalks somewhere else and then you will require a low-volume cert.
:twisted: Wellington's TS Midget :twisted:
gurutasker
Re: Seats too high
Postby Rick » Wed Jan 10, 2007 5:22 pm
xRyanx wrote:So to begin with im 6'3. My seats in my bzg, while low enough, are still quite high for me. Im not hitting my head on the roof, but its close.
Tell me about it, Iam 6'4 and it doesnt help when you wear a helmet on track days, its even worst in my AE85 my head is nearly at right angles with the race seat on the factory rails and cage in there. I ended up making new mounting points as low as possible. Quite a bit of work.
Have you seen the seat on trade me? I would have a look at it first if you were interested in it.
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Toyota/Interior/auction-83814697.htm
Postby flygt4 » Wed Jan 10, 2007 5:23 pm
gurutasker wrote:Also watch that if you're seat belts are mounted to the seat (which I think they are on the AE111's) and not the chassis. If you try and go after-market with your seats you will have to re-mount the seat belt stalks somewhere else and then you will require a low-volume cert.
if you are creative there is a way around it apparently, as the same issue applies with ae101.
flygt4
Sometimes
Postby andyztouring » Wed Jan 10, 2007 7:51 pm
Sometimes you can reduce the amount of padding in the cushion foam,best to see a car trimmer/upholsterer.
andyztouring
Postby gurutasker » Wed Jan 10, 2007 9:50 pm
flygt4 wrote:if you are creative there is a way around it apparently, as the same issue applies with ae101.
Yeah I think it has something to do with using the factory bolts and locations of some AE101's that had them mounted to the chassis.
gurutasker
Postby xRyanx » Fri Jan 12, 2007 8:17 pm
Cheers guys,
So it looks like if i go after-market ill have to make some custom brackets like rick.
Ive seen the pictures on your link, many thanks, any more info regarding them?
xRyanx
