3sge block 3sgte head
Postby Infinite » Sun Jan 14, 2007 10:16 am
Ok had a quick look thru the first 4 pages of search but didnt find much
I have a gen 1 mr2 3sge block and a gen 3 3sgte grp a engine what would happen if the head from the gte fell on to the ge and then was assembeld :P and run a link lem v5? how long u reckon it would last and what psi shld it run any idea on power
Lots
Infinite
Postby solitaire » Sun Jan 14, 2007 10:43 am
The more technical guys will corect me if im wrong...
But providing that all the oil and water lines in the block line up, it should be fine... the main limitation would be compression of the 3sge pistons...
if you have a grpa engine why dont you just throw the whole thing in the car?
Failing that just swap it with someone on here for a gen 1 3sgte :D
AE92, KZJ120, KDJ120
solitaire
Postby Infinite » Sun Jan 14, 2007 10:49 am
cause im thinking high comp low to medium boost :P if it holds for a while ill upgrade the 3sgte block then when the ge blows ill put it all back together as a 3sgte grp a motor but would be interesting to see what sorta power it could do befor it blows
Lots
Infinite
Postby MrOizo » Sun Jan 14, 2007 11:03 am
Pretty sure you have a Gen2 engine - thats the one from the MR2's.
Talk to Adydas about it all.. he's pretty much done all that ;)
MrOizo
Toyspeed Legend
Postby Infinite » Sun Jan 14, 2007 12:15 pm
oh ok its a 1990
Lots
Infinite
Postby SUBARUCONVERT » Sun Jan 14, 2007 3:13 pm
yeah thats gen2
3ST150
SUBARUCONVERT
gen 2
Postby Celica RA45 » Sun Jan 14, 2007 4:10 pm
for 1 thing is thou they dont have oil sqirters and most gen2 and gen 3 turbo motors did even the gen 1 turbo for that matter
Celica RA45
Postby KE20 » Tue Jan 16, 2007 4:43 pm
it works fine, i ran a gen2(celica) gt head on my gen1(celica) na block. it ran fine, just dont run high boost
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Postby gordon77 » Tue Jan 16, 2007 7:01 pm
just out of intrest, does it work the other way around? - can u use a gte bottom end with ge head?
What is RR?
gordon77
Postby Infinite » Wed Jan 17, 2007 8:13 pm
gordon77 wrote:just out of intrest, does it work the other way around? - can u use a gte bottom end with ge head?
yes unless u actuley want to go some were lol wld be low comp crap power...
Lots
Infinite
