Fact or fiction??
Fact or fiction??
Postby TOYROTA » Wed Jan 31, 2007 3:17 pm
i read some where that if you slightly overbore a k motor you can fit 16v 4age piston into it. can anyone confirm this and wout there be any advantage apart from strength.
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby Punter » Wed Jan 31, 2007 4:52 pm
4age bore = 81mm
K series bore = 75mm
Common sense would say no.
But I believe 1ggze pistons are the 75mm bore and are apparently the same construction as 4agze pistons. So thats probably what your thinking of.
Punter
Postby Dell'Orto » Wed Jan 31, 2007 5:17 pm
Do 1G pistons have valve cut outs in them? Unless you were going to turbo it, I'd say the valve cutouts would be more of a hinderance.
Postby evil_si » Sat Feb 03, 2007 12:23 am
scott why the fuc**K are you thinking of playing with a k series?
ditch it and run a jz :lol:
evil_si
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
