A Small Problem With My Corolla?
Postby Quirky » Thu Feb 08, 2007 12:42 pm
Righty'o
My Corolla has had this problem for a while, that is, when your in 5th, accelerating and de-accelerating, the stick moves quite a bit. Only in 5th gear.
Now just recently, the play in the stick has moved so much, that when i accelerate in 5th, and depress the pedal really quick, it pops right out of 5th gear.
Would just like to know, how major is this problem?, and about how much will it cost to fix?
Chris
Quirky
Postby barryogen » Thu Feb 08, 2007 1:20 pm
my dads hilux has this in first... problem is some springs of some sort according to the mechanic(he worded it better, but I seldom listen)... nothing to worry about so he said, although I'm not a mechanic, and I always thought he was a dodgy bugger. The hilux takes off fine in second, so no biggy if it loses first anyway.
barryogen
2ZZ Guru in training
Postby thegreatestben » Thu Feb 08, 2007 2:10 pm
Its a common problem With the 'C' series fwd boxes.
My GF's AE92 GT pops back and forth in 5th
thegreatestben
Postby no_8wire » Thu Feb 08, 2007 2:19 pm
As said common problem in early C5* boxes...eg C50's etc...
no_8wire
Postby Punter » Thu Feb 08, 2007 3:01 pm
Could also be engine mounts, but as said could just be you gearbox weraing out.
Punter
Postby pc » Thu Feb 08, 2007 3:10 pm
Common problem, cheapest option is to replace with a pick-a-part one that is ok.
cost $77, $69 if you take the old one back.
and a day with a socket set.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Quirky » Thu Feb 08, 2007 4:04 pm
is there anyway to fix the problem?
Or has the gearbox shat itself, and will need a new gearbox?
thing is, it worries me when it goes out of gear, into neutral without the clutch...
Quirky
Postby barryogen » Thu Feb 08, 2007 4:29 pm
Quirky wrote:is there anyway to fix the problem?
It should only do it when there is relatively little pressure on it, otherwise the pressure applied by the engine should hold it in gear. which from reading what you wrote is the opposite to what it is doing... I bow out at this point and leave it to more knowledgeable people.
barryogen
Postby thaphatty » Thu Feb 08, 2007 6:51 pm
things to do:
1. Check your engine/gearbox mounts for a broken one. particularly front and rear ones (rear one is a bugger to get to to look at but its worth the time/effort)
2. Check your gear shift linkages for slop (under the gear shift boot and the bushes on the gearbox)
3. Take it to a Transmission place and ask them to look at it for you. Could be (god.. not interlocks but the other ball bearing things in gearboxes that help hold the selector shafts/forks in place....the name escapes me) This is usually a relatively easy task. they just unbolt a small plate on the side of gearbox (unsure of location on a "C" series) and 3 round (duh lol) ball bearings and springs should pop out.
p.s. dont loose them :D
thaphatty
Postby no_8wire » Thu Feb 08, 2007 7:01 pm
On a C5* series...only way is to strip it down to get those bearings... :wink:
While your car is not a AW11 here is something you might find interesting...
The 85-86 Mr2 had the C-50 transmission while the 87+ NA models had the C-52, which was an upgraded and strengthened version of the C-50. This included stronger input and output shafts with larger diameter bearings on some of the gears, along with updated syncros. The C-50s are notorious for having what's been described as the 5th gear popout. This is where 5th gear will pop out engagement when the throttle is applied. Some C-52s also have this problem. The trannys will also sometimes have bad 2nd or 3rd gear syncros. While one might think that these trannys are not that great because of all these problems, this is not entirely true. If treated correctly, with a somewhat periodic changing of the tranny oil, a C-50 or C-52 can handle great amounts of power and last a long time. If you have the 5th gear pop out problem, first check your tranny and engine mounts to see if they are worn out and causing too much engine movement. After that, some have been able to stop the problem by replacing the 5th gear and synchro, others have not.
no_8wire
Postby thaphatty » Thu Feb 08, 2007 7:37 pm
no_8wire wrote:On a C5* series...only way is to strip it down to get those bearings... :wink:
I stand Corrected. I havent taken apart a "C" series Box before. :)
thaphatty
Postby Ae92typeX » Thu Feb 08, 2007 10:31 pm
really, id go with the aboves...but...
there used to be a dude on this forum a few years ao who had bent a coathanger to hold the stick in 5th...lol, cant recall who - anyone want to own up...
Ae92typeX
Postby Quirky » Fri Feb 09, 2007 1:20 am
now theres an idea...
Quirky
Postby johntramp » Fri Feb 09, 2007 1:35 am
Quirky wrote:thing is, it worries me when it goes out of gear, into neutral without the clutch...
thats ok
johntramp
Postby Quirky » Fri Feb 09, 2007 10:40 pm
thats ok
please dont be scarcastic, im very clueless when it comes to cars...
Quirky
Postby Alex B » Fri Feb 09, 2007 10:49 pm
Hes not, hes saying its not doing any more damage than is all ready done.
Postby Quirky » Sat Feb 10, 2007 4:40 am
ahh right, ahh well, thanks for all the info, looks like cant do too much anymore, although i would like to keep the car in, "good condition" thanks all.
Chris
Quirky
