20v + LEMG3
20v + LEMG3
Postby Santa'sBoostinSleigh » Thu Aug 09, 2007 2:26 pm
anyone happen to have any tips/hints/diagrams for wiring a LEM G3 up to a N/A 20v 4AGE?
what spark setup should i run?
what injection method should i run?
do i need a ballast resistor for the standard injectors?
any advice/info/diagrams etc appreciated :)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby IH8TEC » Thu Aug 09, 2007 2:36 pm
you need to find if the std injectors are low or high impedance, most like run as group.
ignition should be straight forward and in the g3 manual
Postby Santa'sBoostinSleigh » Thu Aug 09, 2007 2:42 pm
multipoint group, or group/staged?
ignition theres all sorts of stuff such as wasted spark, direct spark, distributer ignition etc
Santa's Mega Sale
Postby Logan » Thu Aug 09, 2007 2:48 pm
dizzy is fine,
group injectors in pairs (as per factory loom)
20v blacktop injs are hi impedence and can be wiried directly.
Make sure you get the tps wires around the right way also and get 0-5v variation, if you get them around the wrong way you will only get 4-5V and it will look like a dodgy TPS sensor...
can use factory air temp sensor etc.
vvt can be dirven directly from comp output i think.
SR Sold. Onto Other Things
Logan
Postby Santa'sBoostinSleigh » Thu Aug 09, 2007 3:06 pm
from what i just found using the TS search: BT + ST 20v injectors are identical, and are 295cc, high impedance
Santa's Mega Sale
Postby AceSniper » Thu Aug 09, 2007 3:08 pm
Logan wrote:20v blacktop injs are hi impedence and can be wiried directly.
In thery yes but mine backfired bigtime blowing 1m+ flames... put resistors on (x15watt jay car jobies ($2))
AceSniper
Postby Burning Angel » Thu Aug 09, 2007 7:50 pm
when i installed one i had the following setup(was on a silvertop)
injectors are high imedance so i wired them directly in pairs(inj1 to injectors 1 & 3 and inj 2 to injectors 2 & 4) set the injection mode to multi point group.
ignition you want to use distributor with rising dwell edge
check the resistance of the vvt solenoid as to whether it can be driven from the aux output. i cant remeber but i ran it through a relay neway.
triggers should be set to cam and the sync also on cam. they are reluctor type
Burning Angel
