AW11 over heating
AW11 over heating
Postby FST4RD » Tue Oct 16, 2007 7:54 pm
Tryied to search nothing that fits....
Started you the AW11 that i'm restoring to let it idle for a while and the temp gauge started raising as I expected then I noticed steam coming out the overflow bottle do dacky. Temp gauge was about 2/5's of the way up. Turned the car off and then went round to the front and the radiator was stone cold.....
Is this normal?
Maybe there's a block somewhere?
Any suggestions?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Leon » Tue Oct 16, 2007 8:56 pm
I'd start to suspect the cooling system needs bleeding, or that the radiator may be blocked.
Postby Adamal » Tue Oct 16, 2007 9:01 pm
Hmmm... I'd say theres a blockage. Overflow bottle is on the other side of the thermostat, so wouldn't be that.
Postby Mr Revhead » Tue Oct 16, 2007 10:53 pm
maybe an air lock.
restoring... is/has there been any leaks?
are you aware of the bleed valves in the cooling system?
Postby ollieboy » Tue Oct 16, 2007 11:34 pm
ollieboy
Postby FST4RD » Wed Oct 17, 2007 7:20 am
Thanks guys, it's been running, i used to drive it round all the time, but then I decided to fix 1 piece of rust and the rest of the story is history :lol: Every so oftern i crank it over to keep the battery and all other bits and pieces going.
Might pull the radiator out just for fun and flush out the system I think.
Anyone know the best way to refill and how much fluid it actually takes? got to get some antifreeze...
FST4RD
Postby 85AW20v » Wed Oct 17, 2007 7:38 am
Takes around 12 litres. Have a nosey at this link on Club AW on bleeding it. http://www.clubaw.co.nz/forum/viewtopic.php?t=1893. Could also be your thermostat stuck shut.
See ya
Simon
85 MR2 20v
85AW20v
Postby Mr Revhead » Wed Oct 17, 2007 8:58 am
the key thing is to remember to open the bleed valves.....
especially the one off the heater tap and radiator.
FIRST.
