Clutch Change in my ee80 (2e engine 5spd)
Postby xsspeed » Thu Nov 15, 2007 5:05 pm
Hey, just a few questions
I need some lithium grease with molybdenum disulphide, where should i get it from, dont need a huge tub.
Also has anyone used a clutch alignment tool, should i bother getting one, if not, what should i use? (besides an old input shaft)
Postby Lloyd » Thu Nov 15, 2007 5:23 pm
What exactly do you need the grease for?
As for aligning the clucth, just feel around the edges and have a look down the middle to see if its straight.
Postby xsspeed » Thu Nov 15, 2007 6:03 pm
this is my 1st time doing the clutch myself :o , just going by a haynes manual, says i need grease.
'lubricate the gbox input shaft splines, release bearing guide sleeve, inside of release bearing ... etc... with lithium based greased with molybdenum disulphide"
Postby postfach » Thu Nov 15, 2007 7:13 pm
for the alignment tool, you can use a piece of dowel or an extension from a socket set with electrical tape wrapped around it for a snug fit. don't touch the clutch plate with greasy fingers :wink:
postfach
Postby Lloyd » Thu Nov 15, 2007 7:15 pm
Just find some CV grease or similar, should be sweet. As for lining the clutch up, you should be able to feel around the edge to see if it lines up properly.
Postby rollaholic » Thu Nov 15, 2007 8:53 pm
we use wheel bearing grease at work ;)
oh and clutch alignment tool is handy, but i wouldnt buy one to do one clutch.
Postby xsspeed » Thu Nov 15, 2007 9:10 pm
lithium based grease seems to be pretty standard, i cant say i know much about the molybdenum disulphide
Postby Alex B » Thu Nov 15, 2007 9:47 pm
Its a pretty standard use grease, just like the CV stuff
Postby xsspeed » Fri Nov 16, 2007 4:33 pm
so i got some bp energrease, ls-ep 2, from Ripco. 8 bucks so cant complain, says its multi-purpose. there was valvoline that had said it had that molybdenum disulfide in it, but was in a massive tin.
this bp stuff looks like the right sort of thing
Postby fx gt » Fri Nov 16, 2007 5:08 pm
good luck.i just did mine in the fxgt.took me a week to do.
didnt help that repco got me the rong clutch and had to wait for the next day.
used my eye cromoter with the clutch and it goes sweeeet.
fx gt
Postby xsspeed » Fri Nov 16, 2007 5:47 pm
i've got the right parts, got toyota parts for cheap, only reason i'm doing it is to get car back on road for a bit untill i'm ready to put the silvertop in it.
Gunna do it over the weekend. i hope :D
Users browsing this forum: Bing [Bot] and 13 guests
