thx in advance
barryogen wrote:on the AE101 it means that you can have a fairly restrictive muffler on the end meaning that it would be quiet until you give it hell, and it opens the flap/valve to the other muffler to increase the flow...
that and it looks phat...
~SlideWays~ wrote:barryogen wrote:on the AE101 it means that you can have a fairly restrictive muffler on the end meaning that it would be quiet until you give it hell, and it opens the flap/valve to the other muffler to increase the flow...
Really? I never notice an exhaust note difference in the gf's car. But with the car idling on a cold morning you can see fumes/steam coming from only one of the silencers. I just assumed that the flow just went through the easiest path...
Having a look under it and the Y-piece is a bit hideous!You sure there's a flappy jobbie?
~SlideWays~ wrote:Having a look under it and the Y-piece is a bit hideous! :lol: You sure there's a flappy jobbie?
sergei wrote:I have not seen any flaps in AE101 exhaust, is it inside of the muffler?
barryogen wrote:I believe that the flappy bit is spring loaded and is inside the secondary muffler.
Revhead can probably explain it better.
