*Update* Altezza (3sge) REtuned, ~120kwatw
Postby barryogen » Fri Nov 09, 2007 4:07 pm
That is a stunning looking header, will be interesting to see what difference it makes with the much longer primaries, and much shorter secondaries.
barryogen
2ZZ Guru in training
Postby Titties » Fri Nov 09, 2007 5:20 pm
whats the theory behind header lengths?
for primaries and secondaries?
i know how all the scavenging works for certain RPM etc, but not really sure how the 4-2-1 works
'98 RS200 Altezza - SOLD
'96 Mitsi Mirage, 11.12 @ 124mph (200kph)
Titties
Postby Titties » Tue Nov 20, 2007 2:23 pm
Power FC now working (earthing Fault on my car).
Booked in for tuning @ Speedfactor, Tauranga on Monday.
Will post results.
Cheers, Mike
Titties
Postby Titties » Tue Nov 27, 2007 12:10 pm
Pics of the dyno results -
speedfactor did a great job with the tune.
Red line is the PowerFC with the base Maps
Blue line is the tuned map.
Took 29 runs and about 1.5hrs on the dyno.
Running quite rich (for a NA car), they tried to lean it out but it just lost power.
The VVT-i settings on the base map were almost perfect, only thing they changed was 3 degrees intake for the last ~2000rpm (you can see the power jump).
Apart from that, the Base map is really good, just the fuelling is a little rich.
I didn't do a run with the standard computer in.
Compared with the standard computer, the midrange is alot better, now there isn't the torque hole from 3.5k to 5.0k rpm.
Much more pleasant to drive :)
Next on the list is to fit the Oil cooler i got, get some good brake pads and get some sway bars and she'll be ready for some track days :)
Cheers, Mike
Titties
Postby IH8TEC » Tue Nov 27, 2007 12:40 pm
thats pretty good effort there titties, shame you can't go to drags on friday.
Postby Titties » Tue Nov 27, 2007 12:43 pm
Many Many Alcohol to be drunken this weekend :)
I'll drag it again after Xmas, that way if i break anything i wont be in a rush to fix it :)
With the power increase, prob look at about 14.5ET
Titties
Postby Lith » Tue Nov 27, 2007 1:08 pm
Thats very impressive!! Well done :D Cool to see one making a bit of power, though will be interesting to see if it can go much quicker than a high 14 - they are quite heavy cars.
2007 Mazdaspeed Axela
Lith
Postby RomanV » Tue Nov 27, 2007 4:07 pm
Holy crap in a hat!
That's a freaken awesome effort, just from ECU and extractors!
I think I'll have to copy your setup. :lol:
Postby Titties » Tue Nov 27, 2007 4:15 pm
RomanV wrote:Holy crap in a hat!
i got a good exhaust too, 2.5" mandrel, 1x resonator and a Twin Loop Replica from Beyond Motorsport, Really good guys there.
And it's quieter than what i had previously.
If you want to check it out sometime RomanV, lemme know and we can meet up
Cheers, Mike
Titties
Postby Crampy » Tue Nov 27, 2007 4:49 pm
Shot Titties 8)
Good increase and it sounds sweet too.
I hate seeing Altezza's with modified exhausts that have that yuck tinny sound. Your one is much nicer to the ear :)
Crampy
Postby IH8TEC » Tue Nov 27, 2007 4:50 pm
be interesting to see what power it has on the dyno you used originally, for a more comparible figure that you gained. just saying cause i dont look at outright power, i look at whats gained.
did it gain much better driveability?
Postby mr30%jr » Tue Nov 27, 2007 5:02 pm
the power FC wont do shit if your maf setting is wrong.. the air cant be turbulating like it will from a pod it needs to be going straight over it
mr30%jr
Postby Titties » Tue Nov 27, 2007 6:55 pm
mr30%jr wrote:the power FC wont do sh*t if your maf setting is wrong.. the air cant be turbulating like it will from a pod it needs to be going straight over it
i put honeycomb mesh before the Air flow meter to ensure the air isn't turbulating.
Even if it was, you could tune it out via the Power FC anyways.
IH8TEC wrote:did it gain much better driveability?
yeah it's way better, the mid range torque is alot more usable.
when shifting to 2nd from 1st, there is power on tap now. Unlike before when it was very hard to get a smooth shift cause i was moving into the torque hole.
I know what you're saying about the Dyno, but it's not worth the money to get it rerun.
I'm happy with how it turned out :)
Titties
Postby Dell'Orto » Thu Nov 29, 2007 6:56 pm
Just split off the exhaust header stuff to another thread.
Postby Titties » Thu May 22, 2008 3:30 pm
Car Retuned,
heaps more torque midrange.
More info -
viewtopic.php?p=655744#655744
Titties
