Freeboosting
Freeboosting
Postby Brick » Thu Jun 26, 2008 7:42 pm
What can cause a turbo to freeboost?
I no its not the turbo (had that checked out)
All the hoses are connected.
But what else can cause it? Faulty BOV? boost controller?
any help appriciated
Brick
I know Kung Fu
Postby Lloyd » Thu Jun 26, 2008 7:47 pm
Well the wastegate has to be shut all the time. So either the wastegate is stuck shut, its not getting a boost feed, stuffed diaphragm etc
Postby escortman » Thu Jun 26, 2008 7:51 pm
boost controller not working actuator stuffed ?
4x4 toyota blizzard offroader
escortman
Postby touge rolla » Thu Jun 26, 2008 7:56 pm
having factory boost control still connected to the system.
what sort of car/turbo/controller?
touge rolla
Postby Brick » Thu Jun 26, 2008 10:19 pm
the actuator is apparenlty fine, as thats what i thought it was so took in to tubo place
its a tdo5 on a 4g63 and had a turbosmart whindy thing controller
Brick
I know Kung Fu
Postby escortman » Thu Jun 26, 2008 10:38 pm
had u tried running it with out the boost tap in?
a mate of mine bought a libero gt which open boosts cant figure out why been over all lines etc, it threw a rod haha, now hes just going external
escortman
Postby Lloyd » Thu Jun 26, 2008 11:04 pm
As above take the boost controller off and see if its alright then
Postby matt dunn » Thu Jun 26, 2008 11:50 pm
HRT wrote:As above take the boost controller off and see if its alright then
yeah,
run a pipe straight from the pressure source to the actuator and see what happens.
Postby dr_ed » Fri Jun 27, 2008 12:29 am
Hey, Have done a lot of work on a mates Evo (4g63),
When he first had the car he decided to put a 3" exhaust on it, which for some reason caused it to free boost, he blew a Headgasket so he decided to make the car into a weapon, anyways....
It could quite possibly be something similar if you have an exhaust of similar description. But I would also suggest blocking up the boost controller feed and eliminating that first.
dr_ed
Postby tsoob » Fri Jun 27, 2008 11:45 am
yeah,
also check all your vac lines are hooked up to the correct places, or get an external!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby method » Fri Jun 27, 2008 2:57 pm
freeboost is gangsta. Leave it
PICS UPDATED DAILY
method
Postby tsoob » Fri Jun 27, 2008 4:12 pm
method wrote:freeboost is gangsta. Leave it
LOL OF THE WEEK !!!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby FXGTV » Fri Jun 27, 2008 4:43 pm
HAHAHAHA, classic.
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby Brick » Fri Jun 27, 2008 6:47 pm
I know all the lines are correct because it was fine and nothing had been touched, it just happened.
Ill take out the boost controller and see if that fixes it
Brick
I know Kung Fu
Postby Caveman » Fri Jun 27, 2008 9:28 pm
May have burnt a line or something fell off? As everyone has already said could be...
- no vac/pressure to actuator
- actuator stuffed (diaphragm?)
- wastegate vent jammed somehow
- boost control broken
anyway hope you manage to sort it.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Santa'sBoostinSleigh » Fri Jun 27, 2008 10:23 pm
ive had a wastegate actuator perish causing freeboosting
from memory we used my air compressor to put pressure in all sorts of lines and see if things moved when they were mean to - wastegate actuator arm wasnt moving
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby FULLOC » Sun Jun 29, 2008 4:15 pm
just run a new piece of piping between comp housing and actuator to be sure. and id suggest pulling turbo out and checking wastegate flap as suggested above. turbo is easy to remove/refit in under an hr.
i had a gsr for a couple years and had a few similar issues such as running open boost or not boosting at all. usually always was turbo/ wastegate related.
FULLOC
Postby Brick » Sun Jun 29, 2008 5:01 pm
FULLOC wrote:just run a new piece of piping between comp housing and actuator to be sure. and id suggest pulling turbo out and checking wastegate flap as suggested above. turbo is easy to remove/refit in under an hr.
i have already changed hoses and the turbo has been in to be checked out and is fine.
Brick
I know Kung Fu
