SW20 tyre sizes *SORTED*
Postby GDII » Thu Jul 03, 2008 6:44 pm
What size tires should I have on the 15" wheels on my SW20?
I have 6" wide on the front and 7" on the back.
The car had a set of GT radial 205 50 15s on the back and looked a little small for the car.
They had flat spots on them so I replaced them with 205 50 15 Dunlop Direzzas and they look even smaller and stretched.
Not too happy about the looks. Should have done some research first.
I have 195 55 15 on the front and they look fine.
GDII
Postby Dell'Orto » Thu Jul 03, 2008 6:48 pm
225/50/15's from memory
Postby postfach » Thu Jul 03, 2008 6:49 pm
you should use 215/50 on the back, they will be the same sidewall height as your 195/55 so will look right.
for your reference:
If you change the word stock to front, and new to rear, the application can be used to compare front and rear tire circumference, and as you can see they are near enough to identical.
postfach
Postby Boosted_162 » Thu Jul 03, 2008 6:51 pm
I run 205/50/15s and 225/50/15s on mine.
Postby postfach » Thu Jul 03, 2008 6:56 pm
out of interest, since your running factory wheels, does it not say inside the drivers door what size you should use?
postfach
Postby GDII » Thu Jul 03, 2008 7:19 pm
postfach wrote:out of interest, since your running factory wheels, does it not say inside the drivers door what size you should use?
No, Because this is a 1990 SW20 with later model wheels. It had 14" from factory.
Boosted_162 wrote: I run 205/50/15s and 225/50/15s on mine.
Well in that case I will buy some 225/50/15 for the back and swap the back tires to the front wheels.
http://i186.photobucket.com/albums/x281 ... 2005.5.jpg
Is this photo showing that setup?
GDII
Postby Boosted_162 » Thu Jul 03, 2008 7:33 pm
Nah back then it had 195/55/15 on the front. But was still 225/50/15 on the rear.
Thats with 205s on the front. Man i hate that white bumper :( :lol:
Postby GDII » Thu Jul 03, 2008 7:41 pm
At least your wing mirrors aren't pink :oops:
And i don't have the lights in the front bumper. Hope I can pick up some cheap. Would finish off the front nicely with the bigger front lip.
GDII
Postby Boosted_162 » Thu Jul 03, 2008 7:43 pm
GDII wrote:At least your wing mirrors aren't pink :oops:
I dont run spotlights either. But it looks 100x better when theres no cutout for them :D
Postby GDII » Thu Jul 03, 2008 7:56 pm
Yea the big gapping holes don't look too good.
Thanks for helping me out guys! Much appreciated.
GDII
