HID lights
Postby touge rolla » Mon Jul 28, 2008 10:34 pm
that is exactly what it says right here
http://www.landtransport.govt.nz/vehicl ... right.html
touge rolla
Postby NZ_AE86 » Tue Jul 29, 2008 10:31 am
touge rolla wrote:that is exactly what it says right here
That means nothing! A WOF is issued in accordance with the VIRM.
If would be helpful if they had everything aligned to avoid confusion!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Mr.Phreak » Tue Jul 29, 2008 11:01 am
I thought it would be covered under the performance section
VIRM wrote:22. A headlamp must be fitted with a light source that
is specified by the vehicle manufacturer or the
headlamp manufacturer.
Mr.Phreak
Postby Lloyd » Tue Jul 29, 2008 12:48 pm
But if you read the corresponding reason for rejection...
f ) the centreline of the light beam projects to the
right of the vehicle’s centreline, or slopes down
from the lamp at angles other than the following:
i. as specified by the vehicle or lamp
manufacturer, or
ii. as specified in Table 4-1-1.
So if it either meets the pattern required in the table, or meets the manufacturers orignial setup then it has no reason to fail.
Postby Mr.Phreak » Tue Jul 29, 2008 2:30 pm
Meh, there's something specifically saying bulb replacements are illegal on the LTSA site, and I'm guessing if you contacted them, you'd get the same answer.
So I'd rather not be the first guinea pig to test the system, I have the luck of Job, and would probably end up in a head on at night with the other driver claiming he was dazzled by my lights.
Mr.Phreak
Postby NZ_AE86 » Tue Jul 29, 2008 7:31 pm
If I was to fail every car that had bulbs that were not recommended by the headlight or vehicle manufacter there would be no cars passing WOF's. That would be if that information was available - if it was I am certain all it would tell you was that the bulbs base should be of the same design eg. H4.
Either way if you brought it to me and it was safe and passed my beamsetter tests then I would pass them!
Current rides;
1986 Levin GT
NZ_AE86
Postby SUBARUCONVERT » Wed Jul 30, 2008 8:10 pm
Hid lights are fine if you can get the correct pattern out of them. and they dont blind you at night, normal rear reflecting hid lights just have a differnt colour and are a touch brighter, its only the hid lights with a focal point in the front of the light that you see change colour.
3ST150
SUBARUCONVERT
Postby Flunk » Wed Jul 30, 2008 9:45 pm
NZ_AE86 wrote:If I was to fail every car that had bulbs that were not recommended by the headlight or vehicle manufacter there would be no cars passing WOF's. That would be if that information was available - if it was I am certain all it would tell you was that the bulbs base should be of the same design eg. H4.
Every wof officer i know fails them... there has been the odd time ive been blinded by the $&#$%.. and i'd blame thier lighting for that, if it happened... i wonder if theyd chase up the issuing warrant officer, if an accident were to happen?
Flunk
Postby NZ_AE86 » Thu Jul 31, 2008 10:32 am
If you can show me where in the VIRM it says they are not legal then I can fail them but I can not fail them because a website said they were not legal even if it is the LTNZ website!
They can chase any WOF officer up if they like but if the WOF has been issued in line with the rules set out in the VIRM then they would be wasting their time! (much like the TRD platform adjustable suspension debate - which will pass a WOF)
The cars you are being blinded by should not have a WOF. If the lights are not aligned or out of focus it should have failed.
I would fail any HID lights that did not have a satisfactory pattern etc.
I would also fail any non HID lights that did not have a satisfactory pattern etc.
I do not make the rules and do not agree with all of them but the rules are the rules.
Current rides;
1986 Levin GT
NZ_AE86
Postby Lloyd » Thu Jul 31, 2008 7:59 pm
Same here
Users browsing this forum: Google [Bot] and 29 guests
