that is exactly what it says right here
http://www.landtransport.govt.nz/vehicl ... right.html
touge rolla wrote:that is exactly what it says right here
f ) the centreline of the light beam projects to the
right of the vehicle’s centreline, or slopes down
from the lamp at angles other than the following:
i. as specified by the vehicle or lamp
manufacturer, or
ii. as specified in Table 4-1-1.
NZ_AE86 wrote:If I was to fail every car that had bulbs that were not recommended by the headlight or vehicle manufacter there would be no cars passing WOF's. That would be if that information was available - if it was I am certain all it would tell you was that the bulbs base should be of the same design eg. H4.
Either way if you brought it to me and it was safe and passed my beamsetter tests then I would pass them!
Flunk wrote:
Every wof officer i know fails them... there has been the odd time ive been blinded by the $&#$%.. and i'd blame thier lighting for that, if it happened... i wonder if theyd chase up the issuing warrant officer, if an accident were to happen?
