Blleding Break lines, For Caliper Paint
Postby Flunk » Sat Aug 23, 2008 1:32 pm
mmk.. so i have bled my brakes before, i know how to use the release valve etc..
My question is, whats the best way to do it, when i want to remove the caliper completely, so that i can clean them up and put caliper paint on?
Normally i bleed the lines, to change pads etc. but never fully disconnect the caliper, so am i correct in thinking its not going to matter how i bleed them, as long as i follow correct procedure to refill the brake fluid system, when i re-assemble?
Flunk
Postby rollaholic » Sat Aug 23, 2008 2:25 pm
some brake line clamps will make it alot easier, stops brake fluid from going everywhere while you have the caliper off, and makes it much faster to bleed when you put it back on.
bleed brakes starting at the caliper furtherest from the master cylinder (usually left rear)
Postby mr_monkey » Sat Aug 23, 2008 2:40 pm
Its no big deal. Just go round and bleed the brakes a few times untill the pedal feels nice.
Oh.. and dont bother with unbolting them. Just cover everything ya dont wanna paint with newspaper.
at the end of the day brakes get dirty fast- any attempt atgetting that area perfect is a waste tbh.
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby Flunk » Sat Aug 23, 2008 5:37 pm
oh i know theyll get dirty... i just want to tidy them up a little... but dont know if ill be able to get them clean enough for paint, without takiung them off the car..
Flunk
Postby mr_monkey » Sat Aug 23, 2008 10:17 pm
degreaser in a can
and rags.
mr_monkey
Postby Bumpy » Sun Aug 24, 2008 9:16 am
Degreaser and lots and lots of rags. Maybe even a toothbrush!
I got some callipers from the wreckers for an upgrade, was a mission and a half to get them clean to paint, but look good now.
What colour are you painting them? White, Red, or the Brembo Gold?
Bumpy
Postby mr_monkey » Sun Aug 24, 2008 12:17 pm
Bumpy wrote:Degreaser and lots and lots of rags. Maybe even a toothbrush!
white with red and gold pokadots.
8)
mr_monkey
