Now, theres like no listing for any suspension for GS300s. So would i assume that Aristos share the same suspension?? Because they are identical pretty much except for options.
Thanks
Mr Revhead wrote:yep, go by the chassis code
just make sure yours hasnt got airbags or something (in the suspension. not interior)
maybe able to help you out with a set of those....
Dell'Orto wrote:Convert it to airbags and flick switches instead
Mr Revhead wrote:??
TEIN are rebuildable in NZ. Not replacement inserts, but fully rebuildable.
one of the few coilover sets that are....
FLAWLES wrote:why teins?
before you buy make sure you can get replacment parts and that the parts are well priced
most guys i know who have had teins cant get them rebulit when bad things go wrong
i run BC coil overs in my jzx100 and have convinced many pple to change over too
parts are cheap and are all of the shelf in NZ
but to answer your Q yes rev head is 100% correct
kim0663 wrote:Mr Revhead wrote:??
yeah i heard they do. Just a question about that. what do they cost to rebuild ? just curious...
Adydas wrote:Wish i knew you could supply teins before i got them from Autolign in Henderson.. Oh wells.
Haha, Craig you need to come for a burn now ive fixed the rear diff mount, installed the new sway bar links and had the alignemtn all done :p
