TRD_ZERO wrote:Im wanting minimum 550cc but what are my options in terms of side feed im i correct in saying blacktop ones are sidefed and i need sidefed ones to replace them? Are 3sgte ones side feed and what cc rating? arent evo ones 550 but arnt they top feed.
AceSniper wrote:black 3sgte side feeds are 440's there is some 550's that are side feed in some 2jzgte's? not sure on colour
Akane wrote:
One thing with injectors is you don't want to go too big. Or else your computer will have problems with controlling them at idle.
You still want a fine mist of gasoline, not flood the chambers with huge droplets.
Why would there be huge droplets?
there is a minimum pulse width that is required to actually get an injector to open.
With injectors too large, the amount of fuel injected may be too much for the engine,
and large injectors have trouble with a good spray pattern at really small pulse widths.
In saying that, the 800's in my 20v idle fine,
But for the MRS we are going to run 8 smaller injectors in staged sequence,
as 4 900cc injectors may be a bit much at idle for a less than 1300cc engine.
method wrote:Cheers for that, i was always wondering why people run a second set of medium sized injectors instead of larger injectors =.
