st215 revcounter
st215 revcounter
Postby phrogmodz » Tue Nov 18, 2008 12:17 pm
does anyone know if the taco output of the ecu
on a st215 gtt will run a standard rev counter
or doses the signal have to be converted?
cheers phill
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby phrogmodz » Mon Dec 01, 2008 9:39 am
wired in standard rev counter and it dont work!
hand held scanner has rev counter signal.
anyone know how to sort this
engine is in a st150
phill
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby RunningRich » Mon Dec 01, 2008 3:07 pm
I always thought Toyotas ran the tacho direct off the ignitor (IG in the check block)?
With Autronic ECU's you need a 1000 ohm resistor between the ignitor and ECU to allow the signal to be read if that helps?
Richard
http://gtfour.supras.org.nz
RunningRich
Postby fivebob » Mon Dec 01, 2008 5:01 pm
Earlier 3S-GTE engines (and most other Toyotas) used a 20v signal from the ignitor, which makes getting the tacho working with an aftermarket ECU a PITA. However this changed with the ST215 and the (12v) signal comes direct from the ECU. This means the signal will not run an aftermarket (coil negative) or earlier Toyota tacho.
Postby phrogmodz » Tue Dec 02, 2008 7:47 am
no supprises there then
do you know the wiring for the factory 215 gauge?
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby fivebob » Tue Dec 02, 2008 12:33 pm
phrogmodz wrote:do you know the wiring for the factory 215 gauge?
Not right now, my manual is in transit from Australia and won't be in my possesion for another 3-4 weeks.
There is another trick you can use that might get a suitable signal for a coil -ve tacho.
Simply piggy-back a non-supressed relay to the ECU's Tacho output. The back voltage spike created by the collapse of the magnetic field from the relay coil when it's switched off may be enough to drive the tacho. Other than that you're stuck with something like a MSD Tach adapter
Code: Select all
ECU ------>Tacho
       V
      Relay
       V
      Earth
