Blue top or red top?
Postby DXROLLA » Mon Jan 19, 2009 7:52 am
Hey im just wanting to know what the difference is between the blue top 4age and the red top 4age? If there is any difference?
DXROLLA
Postby solitaire » Mon Jan 19, 2009 8:31 am
Hiya,
Plenty of info on here, here are some links i found using the keywords "bluetop redtop" in the search function.
In no particular order:
http://home.clear.net.nz/pages/phil.bradshaw/4AGE%20into%20RWD.htm
http://forums.toyspeed.org.nz/viewtopic.php?t=35628&highlight=bluetop+redtop
http://forums.toyspeed.org.nz/viewtopic.php?t=22334&highlight=bluetop+redtop
Pretty general but you get the idea, if you have any specific technical questions best to ask on here to confirm as there seems to be conflicting information on some technical details. But there are some very knowledgable people on here (i am definitely not one of them)
AE92, KZJ120, KDJ120
solitaire
Postby Mr Revhead » Mon Jan 19, 2009 9:44 am
well theres two types of redtop for a start
blue top is the early one, has smaller crank and TVIS system
only real difference between the bluetop and the early redtop is the crank size.
the later redtop (called smallport) doesnt have the TVIS system, which means smaller inlet ports hence smallport. it also has higher compression.
if you can get one, that would be my choice to fit to a car if you had your heart set on a 16v 4age
Postby pc » Mon Jan 19, 2009 9:54 am
yup, bigport redtop is pretty much the same as a bluetop. (both with TVIS)
smallport redtop is very different... and better than the other two.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby DXROLLA » Mon Jan 19, 2009 12:39 pm
Ok thanks was just wondering as i have a blue top and red top sitting at home both with tvis, the redtop looks to be in good condition as far as the block goes but is missing a few things like distributer and throttle body, but the blue top i have has everything but the block needs a rebuild. will the parts off the blue top be able to go onto the red top?
DXROLLA
Postby kim0663 » Mon Jan 19, 2009 5:01 pm
Mr Revhead wrote:only real difference between the bluetop and the early redtop is the crank size.
i would imagine they'd be interchangable?
Mr2 GT-S
330ci M
kim0663
Postby Mr Revhead » Mon Jan 19, 2009 5:15 pm
yeah if you swap the rods and pistons over at the same time
but if you mean you can put an early redtop in the place of a bluetop then yeah
Postby DXROLLA » Mon Jan 19, 2009 6:08 pm
Its going into my starlet so was just wonder if the bluetop distributer and intake will be all good to use?
DXROLLA
Postby Mr Revhead » Mon Jan 19, 2009 6:27 pm
yep they will be
Postby DXROLLA » Mon Jan 19, 2009 6:56 pm
Sweet thanks 8)
DXROLLA
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
