turbos 3071r vs 3076r
Postby IH8TEC » Fri Dec 05, 2008 9:27 pm
thats a pretty cool site, although i dont know how to work out the volumetric efficiency for my engine.
Postby RedMist » Sun Dec 07, 2008 8:05 pm
There is some basic help becide the button. I used a BSFC of .45 however I am running stock compression on a very good flowing engine. I'd try a range of BSFC between .47 and .51 and see if you can get a turbo to suit that range.
Another thing to consider, if you're running a good intercooler ( I run two aftermarket cheap chinese MR2 intercoolers, that work wonderfully!) intake temps will be below the default.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Bazda » Mon Dec 08, 2008 2:54 pm
THis thing is weird, everytime I do mine its in the compressor surge range. And it says I need to use a GT20XX turbo LOL
So I dont get what i'm in putting wrong....
Postby mjrstar » Mon Dec 08, 2008 3:41 pm
interesting site... it would need a bit more research to be able to accurately fill out the fields in regards to efficiency and air temps. but it appears the 57 trim that was on there was no where near it's efficient range at the h.p. level it was putting out... odd..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Bazda » Mon Dec 08, 2008 11:08 pm
mjrstar wrote:interesting site... it would need a bit more research to be able to accurately fill out the fields in regards to efficiency and air temps. but it appears the 57 trim that was on there was no where near it's efficient range at the h.p. level it was putting out... odd..
Dont worry I cant get the thing to work, doesnt look like the temps etc effect the map much if you play with the numbers.
I do not get this at all cos every turbo says im in the surge range haha. (way to the left of the maps)
I find this one to more accurate
http://www.not2fast.com/turbo/glossary/turbo_calc.shtml#sz?FeetASL=0&Tamb=21&Bore=81.5&Stroke=85.5&nCyl=4&RPM=8000&VE=90&Boost=27&Ec=85&Eic=95&PdropIC=0.5&TambIC=21&wiPercentMethanol=0&wiRate=100&wiTemp=0&SFC=0.49&AFR=11.5&maxInjectorDutyCycle=85
Brings up the correct size turbo to what I am running now and its spot on.
Postby mjrstar » Wed Dec 10, 2008 8:50 pm
not bad.. i fiddled with the numbers until i got roughly current power output. i droppped the v.e back as i'm still running stock cams and head, ideal turbo seems to be sitting between the 71 and 76 compressors. or between 57 and 60 trim in the old money.
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby mjrstar » Sat Jan 31, 2009 4:59 pm
to update i have gone with a mtp300 stage 1 off Barry at a good price, it's all fitted but i have not taken it for a run. I'll post up dyno results in the project section when i get time to get it back on the rollers...
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
