AE101 FXGT Blacktop - need gearbox upgrade
Postby alamo » Mon Mar 09, 2009 6:09 pm
I have an AE101 FXGT with a Blacktop engine conversion. Today the factory gear box blew 2nd, 4th and reverse so I need some info about an upgarde.
I'm thinking of going for one out of an AE101 4AGZE with LSD? Are there any other factory LSD boxes I could use for this application?
alamo
Postby Dell'Orto » Mon Mar 09, 2009 6:11 pm
Get a later C56 from an AE111. E series have quite wide ratios, not suited to a 20v torque curve at all.
Postby alamo » Mon Mar 09, 2009 6:22 pm
Dell'Orto wrote:Get a later C56 from an AE111. E series have quite wide ratios, not suited to a 20v torque curve at all.
Was LSD optional on this model? What model's would this box have been in... Levin, Tureno, (Carib ?)...
alamo
Postby Stott69 » Mon Mar 09, 2009 6:39 pm
Can't find the thread at the mo but Rev had posted a thread with alot of info on what boxes had lsds in them and maybe even the ratios. Super strut models i think have lsds in them. Also been told the 5 speed boxes are stronger than the 6 speed ones
Image jzs147 Aristo money pit
Stott69
Postby alamo » Mon Mar 09, 2009 6:53 pm
Stott69 wrote:Can't find the thread at the mo but Rev had posted a thread with alot of info on what boxes had lsds in them and maybe even the ratios. Super strut models i think have lsds in them. Also been told the 5 speed boxes are stronger than the 6 speed ones
Thanks, I'll have a search for that thead. If anyone has a link to it please post it.
alamo
Postby Dell'Orto » Mon Mar 09, 2009 7:13 pm
Yup, BZ-V's had LSD standard. You'll find it in an AE111 model that has a blacktop in it ;)
Postby Crampy » Mon Mar 09, 2009 8:42 pm
C56-04C. Found in AE111s that came factory fitted with Superstrut suspension. The "C" means LSD.
C56-04A is the open diff version.
Crampy
Postby alamo » Mon Mar 09, 2009 9:00 pm
Crampy wrote:C56-04C. Found in AE111s that came factory fitted with Superstrut suspension. The "C" means LSD.
Thanks Crampy.
alamo
Postby xsspeed » Mon Mar 09, 2009 9:24 pm
+1 for crampy's answer
