W - series rwd to 4wd
Postby CelicaGT8 » Sun Mar 15, 2009 9:46 pm
Heya all,
Im building a 1uz celica, but was thinking about makeing it 4wd... more difficult etc, but was wondering about the gearbox.
I currently have a w55
is it possible to get the ratios of the w55 but use like a hilux 4wd box or something... im not sure if its possible, iv played around with fwd boxes but not rwd boxes and not sure whats possible with these boxes.
Or
does anyone no of a seperate transfer case, so i could use the w55 then have a shaft to the transfer case and then on to the diffs...
CelicaGT8
Postby CelicaGT8 » Sun Mar 15, 2009 10:41 pm
I think ill use something like this achually... requires that i cut out more tho....
http://www.trademe.co.nz/Trade-Me-Motor ... 996122.htm
Does anyone have a cheaper one haha
CelicaGT8
Postby strx7 » Mon Mar 16, 2009 5:49 pm
use a G55 or R151 type box
Postby Lloyd » Mon Mar 16, 2009 5:53 pm
Out of curiosity, where are you planning on fitting a front diff?
Postby CelicaGT8 » Tue Mar 17, 2009 4:40 pm
G55 huh, ill google the boxes you mentioned.
The 4wd luz's have the diff in the sump???
If i used a transfer case it would place the front diff close to the left hand side of the sump, so id probably have to make another sump.
But at this stage its really just an idea, if i figerd it all out and it seemed like it was going to work id try it.
CelicaGT8
Postby the fallen303 » Tue Mar 17, 2009 5:00 pm
track down a 1uz from a 4wd aristo?
true house of JZ
Stay true to the origin
the fallen303
Postby strx7 » Tue Mar 17, 2009 5:29 pm
go for a 185 series surf R151 type box, that'll give you the transfer box with the front drive on the LH side, should be able to be mated to a 1UZ front diff
Postby CelicaGT8 » Wed Mar 18, 2009 10:22 am
The 1uz's are all auto arnt they?
Im only interested in a manual.
I have a W-series to 1uz bellhousing which wasnt cheap so i want to use it, it wouldnt fit the surf box would it?
And the ratios of the box would make it drive like a ute wouldnt it?
Im after speed 8)
CelicaGT8
Postby strx7 » Wed Mar 18, 2009 11:05 am
the early type 4wd hilux boxes are W/G series which will mate up with your bell housing, the problem then lies in that the early boxes have the front driveshaft on the RH side, where as the later ones have them on the LH side.
The ratios are OK, 1st gear is generally pretty short in them which means you'll get moving in 1st then need to hook 2nd pretty early. The bottom line is you have to have a comprimise somewhere as you cant have your cake and eat it to which it sounds like you want.
Postby 79rolla » Wed Mar 18, 2009 11:41 am
aftermarket internails? get a 4wd box and change the ratioes in it? will cost and i dont know how avalibail they would be tho.. or how interchangibail everything is..
past: AE82 FXGT
79rolla
Postby strx7 » Wed Mar 18, 2009 11:50 am
you can put R154 internals into an R151/R150 box, but the bell housing wont fit.
Which probably means you could put W57/w58 internals into a W/G55 type hilux box
Postby fangsport » Wed Mar 18, 2009 3:54 pm
4wd liteace and hiace front driveshafts are down LHS
fangsport
Postby strx7 » Wed Mar 18, 2009 4:46 pm
fangsport wrote:4wd liteace and hiace front driveshafts are down LHS
and are Remote shift....
Might be able to mix and match a van transfer box onto a hilux gearbox with W57/58 internals..................
Postby Mr Revhead » Wed Mar 18, 2009 10:44 pm
get RomanV to do it, he'd prob just bolt it all up in an arvo :P
a bell is ringing in my head, its suggesting a memory of G boxes being very very close to W ones..... i think thats where you should be looking.
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
