AE85 Trueno + Levin Fusebox?
Postby matt dunn » Wed Apr 01, 2009 10:58 pm
My Ae85 Trueno came with no under bonnet fusebox.
I managed to get a fusebox and fitted it in fine,
(an AE85 one as the AE86 is supposedly different.)
Now the headlights would not raise or lower,
and after a while tracing the fault,
it turned out to be missing a power feed,
which I traced to a fuse blanked off in the underbonnet fusebox.
If i fed power down the wire the lights are sweet.
Problem is there is no power to the live side of the fuse either,
unless I bridge out another couple of feeds in the fusebox,
and I have no idea what rating the fuse is meant to be.
So, looking for a photo of....
AE85 Trueno underbonnet fusebox, without the cover on so I can see what relays are fitted, and what ratings the main fuses are,
and also if someone has one with the diagram on the lid,
a photo of that too.
matt
Postby shihad » Thu Apr 02, 2009 6:28 pm
yo il try get that photo 2 u as soon as poss
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby frost » Thu Apr 02, 2009 9:44 pm
are you also missing the relay to raise and lower the lights? its separate from the fuse box. also i think the switch on the dash is different
is that what your after? top of it was blank so no help there.
Postby shihad » Thu Apr 02, 2009 10:19 pm
dont think mines blank il check it out 2morrow
shihad
Postby matt dunn » Thu Apr 02, 2009 11:49 pm
frost wrote:are you also missing the relay to raise and lower the lights? its separate from the fuse box. also i think the switch on the dash is different
Exactly the pic you I am after.
I that pink coloured fuse in the corner a 30 or a 40 A,
and if you take the cover off where there is a relay missing beside it,
is there a shorting pin underneath to join to circuits together.
I actually found a good wiring manual on the net last night and may have it sorted now.
Postby frost » Sat Apr 04, 2009 11:20 pm
the pink one is 30a and yes shorting pin under the cover, though i've never tried it
Postby matt dunn » Sat Apr 04, 2009 11:49 pm
frost wrote:the pink one is 30a and yes shorting pin under the cover, though i've never tried it
Thats ok.
I can tell you then that the shorting pin and that fuse are for the Headlight retractor system.
Matt
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
