clearince between crossmember and sump ?
Postby Infinite » Sun Apr 05, 2009 6:09 pm
is there a minimum clearince between crossmember and sump? as i have 5mm lol the engine is mounted with nolothane blocks so no chance its going to actuley realy move when u rev it anyways...
Lots
Infinite
Postby cat007 » Sun Apr 05, 2009 6:51 pm
5mm is probably fine.
Is the car running at the moment?
Get a crowbar in there and see if you really lean on it if you can make it hit....
Postby evil_si » Sun Apr 05, 2009 7:35 pm
i always aim for a minimum of 10mm clearance between any part when doing conversions,
evil_si
Postby Infinite » Mon Apr 06, 2009 8:27 am
my problem is if i have 10mm at the bottom i have 5mm between bonnet and engine! or 5 mm at bottom 10mm at top :/ cant lean it over anymore else ill have the engine laying on the brake master cyl ive got 10mm clearence on that atm if i removed the butterflys from the intake it would give me more room and could lean the engine over and lift it but then id lose bottom end torque/speed...
Lots
Infinite
Postby Lloyd » Mon Apr 06, 2009 8:35 am
Try it and see if it work. If not, hit the sump with a hammer :)
If its pretty solid then you're not likely to have any issues
Postby Mr.Phreak » Mon Apr 06, 2009 11:58 am
Lloyd wrote:Try it and see if it work. If not, hit the sump with a hammer :)
:lol:
Mr.Phreak
Postby QikStarlie » Mon Apr 06, 2009 4:21 pm
5mm will be all good. long as engine mounts arent too soft. my car only has 5mm or so clearance.
QikStarlie
Postby Infinite » Tue Apr 07, 2009 8:29 am
engine mounts are basicly solid...
Lots
Infinite
