water to air set up options
Postby gleem » Sun May 03, 2009 11:23 am
what toyotas came with this set up, also what other cars other than subarus, It seeps the standard price for the complete subaru set up is $100. What option is the best/easiest to intall for 4agte
gleem
Postby thegreatestben » Sun May 03, 2009 11:31 am
I used the gt legacy one in my AW11 with 4agze and there's one in my AW11 with a 7agte.
They fit in quite nicely and piping is fairly straight forward.
Just gotta fit everything (piping, heat exchanger, pump, hoses, etc) in.
thegreatestben
Postby gleem » Sun May 03, 2009 12:34 pm
youd save on quiet a bit of piping wouldnt you, How did you wire the pump up
gleem
Postby Rick » Sun May 03, 2009 1:25 pm
whats it going in? east west or north south configuration?
Postby thegreatestben » Sun May 03, 2009 1:46 pm
I'd just go with a relay which switches on when you turn the ignition to ON.
The subaru pumps are bloody noisy!
Mines currently hooked up to ACC which I will be changing!
thegreatestben
Postby Rick » Sun May 03, 2009 3:49 pm
The best way to control the pump is to have it operated by a temperature switch, Iam not sure how subaru control it and I dont even know if the pump is even rated to be run continuously? I have mine operated by a simple on/off switch as I thought the type of events/driving I will be doing I would have it running all the time during the events etc.
You could have it running off your TPS (through a simple circuit) so when the accelerator is flat to the floor it would come on, there is a number of ways it could be controlled.
Postby gleem » Sun May 03, 2009 5:53 pm
its going in a ae101 gtz to turbo
gleem
Postby Mr Revhead » Sun May 03, 2009 7:30 pm
i had mine wired through a relay to go when ignition to "ON"
i had two, and ran them all the time.
they do make a little noise. i used tap washers (cheap and i had them at the time) to insulate the mounts, worked quite well, and in my aw11 with all the sound deadening removed you couldnt hear them when driving
Postby CelicaGT8 » Sun May 03, 2009 7:56 pm
You could use one off a 3sgte gen 1 or rc gen 2 or 3
CelicaGT8
Postby sergei » Mon May 04, 2009 9:04 am
Gen1 3SGTE one is exactly same as subaru but different plug. Gen3 is a lot bigger.
You could get something from boat shop if you are struggling to find one, just get centrifugal type not membrane.
