speedo recalibration
Postby jakesae101 » Wed May 27, 2009 9:00 pm
discovered my spedo is about 9-10ks out at 100k anyone know where i can get this fixed in wellington
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Re: speedo recalibration
Postby matt dunn » Wed May 27, 2009 10:16 pm
jakesae101 wrote:discovered my spedo is about 9-10ks out at 100k anyone know where i can get this fixed in wellington
Your car and about 90% of the other cars on the road.
Postby Bling » Wed May 27, 2009 11:36 pm
My work van is 5-8km/h slower than the speedo reads @ 50km/h.
Do you have factory sized (overall) wheels?
Postby fangsport » Wed May 27, 2009 11:36 pm
not enough to worry about, unless you want to change your tyre size.
fangsport
Postby jakesae101 » Thu May 28, 2009 5:40 pm
its 8 ks at 70 and just over 10 at 100 slow
jakesae101
Postby cat007 » Thu May 28, 2009 6:04 pm
Robinson Instruments in Auckland can do it
If you give them how much out it is and what fittings they should use - and what car its for - they can make you a step down/up box
Postby fangsport » Thu May 28, 2009 7:50 pm
cat007 wrote:Robinson Instruments in Auckland can do it
i was lead to believe that it was a simple-ish case of telling the technicians what percentage it is out, and they adjust the counterweights and springs in the speedo head??
Matt Dunn would far more versed on the subject, as he deals with Parrots far more often than we do.
fangsport
Postby jaypines » Fri May 29, 2009 9:42 am
you can get the kit from jaycar. http://www.jaycar.co.nz/productView.asp?ID=KC5435&keywords=speedo&form=KEYWORD
adjust to the desired percentage you want. but in your case, error is not linear so i guess just adjust it to speed you want it most accurate.
jaypines
Postby ~SlideWays~ » Fri May 29, 2009 9:45 am
jaypines wrote:you can get the kit from jaycar. http://www.jaycar.co.nz/productView.asp?ID=KC5435&keywords=speedo&form=KEYWORD
Not for cable driven speedo's though.
~SlideWays~
Postby jaypines » Fri May 29, 2009 9:48 am
forgot to say its for electronic speedos :)
jaypines
Postby tsoob » Fri May 29, 2009 1:26 pm
u sure its not just your tyre sizing?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
