stiffening ke35 leavs
Postby 79rolla » Tue Sep 29, 2009 4:48 pm
ok, im trying to see what i can do about my suspension, im going to replace my shocks, its already got 2inch blocks but this only leaves about 2cmish of clearance to the bump stops..
basically wanting to stiffen the suspension up a bit so that it wont hit the bump stops all the time, and give it a bit better handling..
i know you can get the springs professionally reset and stiffened/extra leaf added, but im kind of on a tight budget, anybody know how mutch this costs?
are there any springs that you can add to them for a good result, iv got a ke30 parts car but the leavs all look to be the same length as the 35's ones
it needs to be abil to pass a cert aswell
hope that makes scents, cheres
past: AE82 FXGT
79rolla
Postby Flannelman » Thu Oct 01, 2009 12:41 pm
add more springs. use another set and add in the bigger base leaf or two. will have to use a metal band to locate them (so they dont shift sideways)
not sure on cost to reset the springs
Flannelman
formerly known as Affroman
Postby 79rolla » Thu Oct 01, 2009 2:56 pm
sweet as, iv got it sorted now
just cut the main leaf down from my parts car, and straitened out the clamps to get it in then bent them back after
past: AE82 FXGT
79rolla
Postby Flannelman » Sat Oct 03, 2009 4:19 pm
Thats what you are after!
Put in a good quality shock and your away
Flannelman
