put this on starletcentral but no answer yet:
car - ep82 starlet
motor - 5efhe long block with 4efte running gear ecu injectors etc, with big turbo and a few other things. purchased from dodsons a year ago with 80,000km on clock
everything is together and plugged in/bolted up etc, motor is turning over sweet as, has oil and water
is making spark and firing order is correct
pretty sure its getting fuel as when turning over can smell unburnt petrol coming out of the downpipe (isnt connected up to exhaust yet)
can hear it making compression in all 4 cylanders however havnt done compression test
havnt touched motor since getting it from dodsons, only put new plugs in.
any help as to why its not going?
if you need more info sing out.
thanks alot
