Burnouts + Water temps
Postby stolic » Tue Nov 02, 2010 6:38 pm
l1ttle_d3vil wrote:Cheers stolic, will see if I can find some of that stuff. Different thermostat could be a good idea too so will look into that.
Should line the purple beasts up against each other, see who can make the most smoke. Haha, yeah right... :lol:
you'd probably win that one, she's gonna be a bit cautious with her car first time out and I doubt she'll give me the keys to "test" her clutch :roll:
just a thought also, if your fans are run off your link, maybe have them kick in a few degrees colder and see if that helps at all, you'll need to adjust it if you change the t/stat anyway.
ImageTA22-build - TA22-blah
I envy those with little interest in cars, for they have money and spare time.
stolic
Postby QikStarlie » Tue Nov 02, 2010 7:44 pm
running the fan constant or switching on before (70 deg or so) thermostat opens, when warming the engine up before burnout, might give you a little more time. as you'l be starting with a radiator full of cool water, rather than the system whole system getting up to temp, then fan switching on. wont stop it from getting hot, but should give you a little more skid time before it does.
QikStarlie
Postby stolic » Tue Nov 02, 2010 9:27 pm
QikStarlie wrote: should give you a little more skid time
who couldn't do with a little more of that!! 8)
stolic
