new turbo run in
new turbo run in
Postby tim_blair » Mon Dec 20, 2010 1:38 pm
i made this post a couple weeks ago but ive lost it..........
i just installed a new turbo and would like to know how many ks i want to nana it for to run it in?
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby evil_si » Mon Dec 20, 2010 2:37 pm
No need to run in a turbo, just drive it how you want to from the start
things to make sure of when installing a turbo are
Prelude turbo with fresh oil before starting
On cranking and first start hold the compressor wheel so it won't spin to allow plenty of oil to lubricate it before allowing it to spin
evil_si
Postby tsoob » Mon Dec 20, 2010 5:34 pm
or just take the coils off and turn it over to get oil thru the bearings
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby evil_si » Mon Dec 20, 2010 7:19 pm
Even with removing the coils the turbine shaft will spin when cranking,
Even more so on a brand new turbo with no prelube this is enough to cause irreversible damage to the bearings, if not failure from the start,
Filling the bearing cavity with oil before cranking will help prevent this,
I will always stall the compressor wheel untill I know a good oil supply is present,
I have seen on more than one occasion people will remove the oil feed line and start the engine and run until clean oil comes thru,
In the mean time the turbo is spinning and the bearings will 'pick up' and fail with lack of oil, it doesn't matter what brand, I have seen it happen to brand new garrett's,
They wil then curse and swear that the turbo was faulty, when it was there fault.
evil_si
Postby h8wrxs » Mon Dec 20, 2010 10:44 pm
evil_si wrote:No need to run in a turbo, just drive it how you want to from the start
how exactly do you hold the compressor wheel when cranking?
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby levinguy » Mon Dec 20, 2010 11:11 pm
hold it before you crank it over. get some one else to crank it.. the nut in the middle... with your thumb and index finger.. :lol:
levinguy
Postby h8wrxs » Tue Dec 21, 2010 12:06 am
by cranking it do you mean starting the engine??? or am i missing the obvious
h8wrxs
Postby evil_si » Tue Dec 21, 2010 7:17 am
Yes cranking / starting, but just let it idle if it starts,
hold the compressor wheel or the nut with your fingers,
just get a good grip on it before someone cranks it for you,
Don't jam any thing metal in it to try and hold it as you will more than likely damage it,
Might sound daunting but it is actually very safe
evil_si
Postby h8wrxs » Tue Dec 21, 2010 6:13 pm
evil_si wrote:Yes cranking / starting, but just let it idle if it starts,
yeah i thought thats what you meant... not really keen to try and hang onto that little nut when it spins at 50000rpm-ish....
can ya just fill the oil line with oil before fitting it and spin the compressor by hand to get oil through it?
h8wrxs
Postby rollaholic » Tue Dec 21, 2010 6:41 pm
wont be spinning that fast just cranking it over :)
Postby evil_si » Tue Dec 21, 2010 7:01 pm
Just hold it, it wont spin if you are holding it while someone cranks it,
evil_si
Postby Bling » Tue Dec 21, 2010 7:05 pm
Just don't get ya mrs to do it incase she thinks "crank" means foot to the floor :lol:
Postby tsoob » Tue Dec 21, 2010 10:28 pm
crank it with no coils connected. it cant possibly start, and the oil will still get pumped thru.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby h8wrxs » Tue Dec 21, 2010 10:46 pm
no worries, will give it a go this week when i bolt up my new toy :d
will let you know how many fingers i lose
h8wrxs
Postby d1 mule » Tue Dec 21, 2010 10:50 pm
if you loose a finger im banning you from working on cars ever again.
d1 mule
Postby l1ttle_d3vil » Tue Dec 21, 2010 11:13 pm
h8wrxs wrote:no worries, will give it a go this week when i bolt up my new toy :d
With my car was idling I could put my finger on it and stop the compressor spinning whenever I want.
Postby RedMist » Wed Dec 22, 2010 6:41 am
You could simply build up oil pressure before you crank the engine. It's considerably more preferable than cranking without spark and fuel.
Whenever I start a fresh engine, or start my race engine after sitting for a while I plug up an external oil res (or pot). Mine is simply an accusump that I prefill, then pressurise with straight air. You should build at least 10-20psi of pressure and pre feed all the oil galleries before you turn the crank a single revolution.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
