Suspension clunck - NON susperstrut
Postby eskimo » Thu Feb 17, 2011 9:10 am
Hi
My RN90 Hilux seems to have developed a weird clunk coming from the right hand side when your turning left and go over a bump/uneven surface
I orignaly thought id run over something but its now done it a few times on various left hand corners.
It has been lowered a little but isnt on its ass. I dont think its bottoming out or anything so was wondering what I should look at when under it.
Any suggestions?
Jordon
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby AE82 FXGT » Thu Feb 17, 2011 12:33 pm
check all the sway bar bushes?
AE82 FXGT
Postby eskimo » Thu Feb 17, 2011 3:47 pm
Cheers, will check the bushes and links when I get home
eskimo
Postby 1I1 » Thu Feb 17, 2011 4:13 pm
Check the steering stops - a bolt with a nylon cap on it
TRD Clicky >>Here
1I1
Postby eskimo » Thu Mar 03, 2011 8:09 am
So ive sused out what the clunk is, the muppet who had it befor me has turned the rear bump stops 180d and the right hand U-bolt is hits the chassis rail with decent bump and weight on that side.
Im planning to fit slightly smaller blocks and have the leafs reset a little higher than they are currently set at so I can put the bump stops back to where they should be. This should still leave it low enough for my liking and sit level while still be safe.
Looking at the leaf springs I think one or two leaves have been removed. It currently only has three per side... how many should be there in standard form...4-5??
eskimo
Postby 1I1 » Thu Mar 03, 2011 8:30 am
eskimo wrote:Looking at the leaf springs I think one or two leaves have been removed. It currently only has three per side... how many should be there in standard form...4-5??
Nah only 3
TRD Clicky >>Here
1I1
Postby eskimo » Thu Mar 03, 2011 9:52 am
CHOICE!
Should hopfully solve the problem.
eskimo
