Pros and cons of 1jz-ge dizzy or coil packs
Postby Wickmyster » Sun Apr 10, 2011 4:09 pm
Pros and cons of 1jz-ge dizzy or coil packs. Have engine, but no loom ecu, can only find dizzy atm, no coil packs as yet.
Wickmyster
Postby RomanV » Sun Apr 10, 2011 4:23 pm
What did the engine that you've got originally use?
As the engine will need a crank and cam angle sensor for coilpacks, if it doesnt use a distributor. As well as the ECU/wiring/etc to suit.
Setting it up with whatever the motor came with originally will definitely be easiest solution.
Postby Wickmyster » Sun Apr 10, 2011 7:34 pm
What if it cam with coils, is it easy to put dizzy set up onto it?
Wickmyster
Postby DFECTED » Mon Apr 18, 2011 9:04 pm
you cant mix and match the two, the cams are different
DFECTED
