W55 Bronze bush...
W55 Bronze bush...
Postby lorolla24 » Tue Aug 16, 2011 8:13 pm
Hi,
Need to replace the bush that the gear stick ball goes into.
I have seen a AJPS kit on Ebay.au.
Anybody got one or know someone that can make one in NZ?
Cheers,
Ke35 20v turbo - 200kw atw 13psi
13.5@169km
lorolla24
Postby gepsk8 » Tue Aug 16, 2011 8:39 pm
hey, whats Ur email, will send you picture?
O272754663
gepsk8
Postby CXGPWR » Tue Aug 16, 2011 8:39 pm
Give me the dimensions and a drawing an i can spin one up in the lathe
CXGPWR's 1985 Toyota Trueno Racecar Spec
Build Thread
Discussion
CXGPWR
Postby lorolla24 » Tue Aug 16, 2011 10:32 pm
They are pretty simple by the looks.
I will have a measure up and post it.
This is where i saw it. If you type into Google... "W55 bronze bush" and there is a guy on Toymods who gets them made.
OD need's to be 0.03 bigger so it is press fit.
Sweet.
13.5@169km
lorolla24
Postby limbo » Tue Aug 16, 2011 11:55 pm
I assume they will fit a R154 box as well, If they do I would be keen on one as I was thinking of doing the same thing.
limbo
Postby ryanfels » Wed Aug 17, 2011 8:30 am
ezy10s on here made a run of these maybe a year ago
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
Postby Quint » Wed Aug 17, 2011 12:37 pm
limbo wrote:would be keen on one as I was thinking of doing the same thing.
Would also take 1 or 2.
For W5*
Quint
Postby Ant » Wed Aug 17, 2011 7:32 pm
Heard they make a big difference? I would want one if you have any luck.
Ant
Postby CXGPWR » Wed Aug 17, 2011 10:33 pm
Im happy to make them just need the dimensions & drawings, can spit out a load of them out the cnc lathe
Build Thread
Discussion
CXGPWR
Postby lorolla24 » Thu Aug 18, 2011 8:09 am
Sweet, Glad I'm not the only one that wants this.
The guy from Niteparts said he is in the process of making some.
I just need to knock out the old one and i can take the measurments.
but a bit busy so might be next week.
If anyone else that has a gearbox apart and could measure it? Pretty sure all the w5# are the same.
CXGPWR, how much would you sell them for?
Cheers,
13.5@169km
lorolla24
Postby ryanfels » Thu Aug 18, 2011 8:39 am
Ant wrote:Heard they make a big difference? I would want one if you have any luck.
They feel like a brand new box with it. 0 play in the shirfter
ryanfels
Postby Looonie » Thu Aug 18, 2011 9:37 am
CXGPWR wrote:Im happy to make them just need the dimensions & drawings, can spit out a load of them out the cnc lathe
If you want, I can rip one of out my spare gearbox and drop it off to you, then you can just make bulk copies and flick them on trademe... and I'll take two :)
Rumple dee pumple dee doo...
Looonie
Postby CXGPWR » Thu Aug 18, 2011 7:03 pm
Sounds good as gold, it all depends on the price of the material used, i would think that they will be cheap though
Build Thread
Discussion
CXGPWR
Postby lorolla24 » Thu Aug 18, 2011 7:21 pm
Sounds great,
Think you should be able to use i bit of 30mm bronze bar.
From toymods, they say to put them in the freezer for the night and then heat the other part up with a heat gun and you should be able to press in with a gentle tap of the hammer.
Which is good if you want to put it in while the box is still in car.
Keep me in mind and let me know when you think you will make them.
Cheers,
13.5@169km
lorolla24
