I have trd super strut coilovers all around and trd sway bar now.
Just wanting to know if the trd sway bar will fit the the McPherson hub or do i have to put the standard ones in.
This is what is says on the certification.
Mr Revhead wrote:Why do you want to swap to Mac strut?
Odd that they have put the sway bars on the cert plate
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC wrote:front sway bars are definitely different between MS and SS. I could be interested in the SS TRD one of you go through with the conversion though.
Good luck with that lol. I don't think many do the conversion in the opposite direction. I guess your running a factory rear swaybar? In which case does it under steer much?KIPH8N wrote:RobertC wrote:front sway bars are definitely different between MS and SS. I could be interested in the SS TRD one of you go through with the conversion though.
Yeah if someone could swap their TRD mcPherson one with my super strut one. Really want a good sway bar in my car. Il have to go with smaller brake too.
