mjrstar wrote:^^ true you set a duty cycle, BUT as the OP says it's not displaying the last max boost reached, on each of the pre-sets.
Does it display max boost when you first turn the ignition on?
I actually find the Gizzmo unit in my evo much easier to set than the fiddly Greddy one in my starlet. I guess it just depends on what you are used to..
7ishNZ wrote:I am thinking that maybe I am not holding a stable boost for long enough to have the unit store it.. is it possible?
I am setting duty cycle then gain, but it still reads 0.0 on all the memory settings.
The engine is in a 600kg lotus 7.. it's pretty hard to hold WOT before the redline comes up in 3rd or 4th gear... maybe the boost isn't stable.
7ishNZ wrote:Seems to be working fine now. From what I read, I should be able to run up to about 14 lbs with a stock motor ( with adjustable fuel pressure).
Does this sound right?
iOnic wrote:Pretty sure it's a Caldina 3SGTE.
7ishNZ wrote:It is a 3sgte with stock ecu and adjustable fuel pressure. I have a wideband A/F gauge on it..
[url]http://www.lotus7.co.nz/forum/download/file.php?id=1030[/img][/url]
14 sounds good to me. Thanks.
Users browsing this forum: Majestic-12 [Bot] and 32 guests
